i tried note burner but it didn't work at all. Any other recommendations?
Results 1 to 9 of 9
??? what do you want to do? exactly and in detail.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
so I am getting the same error messages on Sidify Apple Music Converter and note burner. I have did what it said and went into iTunes and checked "share iTunes library xml with other applications" but both software will just blow away. I am using windows 10. Is anyone else having this issue?
Foobar2000 will play just about anything and it has an excellent converter. It comes with presets for the common encoders, and you can create conversion presets with DSPs included.
For formats foobar2000 doesn't play there's generally a third party decoder (DTS and AC3 being examples of that), but it should play MP4s "out of the box".
There's an encoder pack here. https://www.foobar2000.org/encoderpack
The info says you need to install itunes to use the Apple AAC encoder, which isn't accurate. If you have itunes installed already then it doesn't matter, but the "makeportable" file here will extract the required files from the itunes installation file (full installer) so you don't have to install it. -
I know lots of video converter that can help you to convert apple music. But I will suggest you one of the best that is https://downloadtwittervideo.online/ because I used it and I got very good experienced with this.
Myffmpeg converter help!!!
By Hiacios in forum Video ConversionReplies: 5Last Post: 9th Jun 2016, 03:41 -
Oxelon Converter or Something Else
By box-turtle in forum Video ConversionReplies: 3Last Post: 19th Apr 2016, 03:53 -
best multivideo converter?
By Lazare Londaridze in forum Video ConversionReplies: 3Last Post: 26th Feb 2016, 09:36 -
Basic question about scenario Converter > VirtualDub > Converter
By XenonS in forum Video ConversionReplies: 12Last Post: 14th Oct 2015, 09:32 -
3d converter
By 3dtom in forum Video ConversionReplies: 1Last Post: 13th Dec 2014, 20:08
