So many amateur podcasters keep giving their microphone a blowjob which forces me to remix it with dynamic compression to make it less annoying to listen to. I'm using Sony's tool in batch mode with the following settings:
and I apply it twice for maximum effect. Now when some ässhole coughs into the mic, it's the same volume as everything else.Code:Attack: 1ms Release: 500ms Threshold: -18 dB Ratio: 4:1
My question is, how can I tweak the settings so I can achieve the same thing in one pass?
That setting may only work properly with audio which already is at a certain rms level, but not with hotter or quieter material. Normalizing won't fix that either, as that works referencing peak volume, not rms.
Unless I'm mistaken, there isn't any onepass magic fixit tool (though I've toyed with the idea of something similar).
You can chain/pipe processes so it can do multiple types of corrections in just one pass. Just not one-size-fits-all.
Scott -
Levelator was designed to even out podcast volume. For coughing and other unwanted noises, maybe warn the people about it and ask them to turn away from the mike or shuffle their papers or whatever more quietly. Maybe make a note of the time and fix it later in a wave editor.
Near the bottom of the linked page they explain what it does and how. -
Corny, I already pipe two passes of that setting so it's not a big deal per se. Are you saying it's not possible to tweak the settings to achieve the same two-pass effect with one?
manono, thanks for Levelator. It appears a lot of tweak-work went into this to make it as natural as possible. But even this I had to do two passes because the quiet parts are still too quiet and the loud parts are still too loud (it also killed a few legitimate quiet parts). My method is a lot less natural but it spreads the wealth more. Levelator is Roosevelt, I need a Stalin. These are smut podcasts I'm working with so they don't need delicate processing.
Did either of you mess with dynamics for music? It's a lot harder. -
Levelor doesn't let you customize settings, but I played around with it in Sound Forge and found a setting that more or less resembles the one I have to do twice. So a -30.5 db threshold and 9:1 ratio is equivalent to -18 dB and 4:1. I can't tell the difference anyway.
Thanks. -
What you usually want to do is set the threshold just above the noise floor (you don't wan to amplify tape hiss, air conditioner noise, other ambient noise, etc.). Then set the ratio to whatever level you want.
getting audio all at same volume
By thecrock in forum AudioReplies: 20Last Post: 2nd Sep 2017, 08:04 -
Volume Leveling?
By Downgraded286 in forum Media Center PC / MediaCentersReplies: 1Last Post: 25th Mar 2017, 08:02 -
increase volume
By loa909 in forum Newbie / General discussionsReplies: 8Last Post: 5th Jan 2016, 11:29 -
Lowering volume
By pub in forum AudioReplies: 2Last Post: 27th Jul 2015, 03:56 -
Volume adjusting
By chazz spacey in forum AudioReplies: 17Last Post: 19th Nov 2014, 15:00
