Hi everyone.
Feel like I'm finally get the hang of Avisynth now, however the scripts are still giving me a bit of a headache.
When I am working with my VHS captures, I commonly encounter the three following problems... Unfortunately I really don't know what they are called so I don't know what to search to fix them. My workflow is jvc hr-s5700am SVHS > S-video > Panasonic ES-10 > Svideo > Diamond VC500 > Virtualdub (HuffYUV Avi).
My issues are as follows...
1. Jumpy frames (I would like them all stabilised so the movie flows smooth)
https://mega.nz/#!X99BFY6I!HD6Y4GxXw_sDsMAGUSvWmhyvKuG77GN-oslXJ7PXmFY
2. Static/Damage on frames (Would like it corrected as best as possible)
https://mega.nz/#!rstzDIQT!fEfjFT91bhun08HGTwogS-7iWKEQgnx9Q3JWeGszg_o
3. Typical horizontal and vertical jitter/static from VHS tapes (Would like it corrected/removed).
Thanks for your work and appreciate any help!
Results 1 to 1 of 1
Avisynth fix Chroma artifacts in PAL DVD CGI cartoon
By Wizard81 in forum RestorationReplies: 1Last Post: 11th Oct 2018, 11:47 -
Is there any filter in avisynth-hood which fix the shaking video?
By Auliya90 in forum RestorationReplies: 2Last Post: 14th Nov 2015, 08:22 -
[Solved] Avisynth : colors problems
By Kdmeizk in forum Video ConversionReplies: 50Last Post: 30th Apr 2015, 08:20 -
AVStoDVD/Subbtitle Creator problems(How to fix warnnings.......)
By pavjos777 in forum Newbie / General discussionsReplies: 0Last Post: 26th Oct 2014, 08:27 -
MotionFlow problems with AviSynth
By fritzee in forum Newbie / General discussionsReplies: 0Last Post: 23rd Sep 2014, 20:05
