    Nov 2014
    Germany
    Hi folks!
    Is it possible to download following with wget or another tool?
    I got from this site following link:
    https://livestream.com/TheRelixChannel/events/8750647
    https://playback2.akamaized.net/streams/25472209_8750647_lsido1m2lzizqg3y7e6_1/exp=156...&ts=1563483600
    When I open this,got following :
    first segment:
    https://playback2.akamaized.net/streams/25472209_8750647_lsido1m2lzizqg3y7e6_1/exp=156...7b243a09640b7/
    segments/25472209_8750647_lsido1m2lzizqg3y7e6_1@4628000p/media-uouc228yh_0.ts?z=p
    last segment:
    segments/25472209_8750647_lsido1m2lzizqg3y7e6_1@4628000p/media-uouc228yh_2760.ts?z=p
    How can I get all files with wget on my HD?
    Any help was great
  2. youtube-dl can download from that site:
    youtube-dl https://livestream.com/TheRelixChannel/events/8750647
    Since it's a live stream you'll have to use CTRL+C to stop downloading.
    Nov 2014
    Germany
    Hi!
    Normally I downloaded all files from there with DTA!
    I got a new PC with Windows 10,the stream ended early in the morning and I could only open on my new PC the link with all the similar segments,which I want to download!
    So I need a batch tool or a program that can download these directly...
    Greetings,
    HJ
  4. youtube-dl automatically appends all the segments.
  5. Member Emeritus
    May 2014
    Originally Posted by ghostrewel View Post
    Hi!
    Greetings,
    HJ
    Past live segments (all the way back to segment 0) can be downloaded with curl or wget using a current acl= value so long as the user agent and referer are correct and the same as was used to obtain a current acl= value.
    My attempt to download segment 0 produced this: 0.ts
    When the stream is no longer broadcasting, availability of the past live segments may stop - or they may be archived and made available for replay. If no replay is made available, the window to download the live stream from the very beginning will end when the stream stops broadcasting.
