Results 1 to 13 of 13
  1. Hi,I need help to download from zee5.
    I want to rip 576p or 720p of https://www.zee5.com/movies/details/har-har-gange/0-0-harhargange
    What to use and how?
    thanks
  2. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    Any hls plugin ( videoDownloadHelper or Stream Detector f.e.) will pick up the .m3u8 streams,after that you can use any of FFMPEG, streamlink, youtube-dl.
    e.g. streamlink:
    streamlink "https://zee5vodnd.akamaized.net/hls/720p/movies/Hindi_Movies/Har_Har_Gange.mp4/index.m3u8?hdnea=st=1563545797~exp=1563548797~acl=/*~hmac=69cbda60e24550e0fdfe469acc7672f0bc0380b43e8447cd3da53e7c28bc9a11" 720p -o file.mp4
    [cli][info] Found matching plugin hls for URL https://zee5vodnd.akamaized.net/hls/720p/movies/Hindi_Movies/Har_Har_Gange.mp4/index.m3u8?hdnea=st=1563545797~exp=1563548797~acl=/*~hmac=69cbda60e24550e0fdfe469acc7672f0bc0380b43e8447cd3da53e7c28bc9a11
    [cli][info] Available streams: 144p (worst), 240p, 360p, 480p, 576p, 720p (best)
    [cli][info] Opening stream: 720p (hls-multi)
    [download][file.mp4] Written 300.4 MB (60s @ 4.5 MB/s)
    wait till it finishes it.
  3. Sviests sir we need your help
    Format : dash
    Codec ID : dash (iso6/mp41/avc1)
    File size : 7.55 MiB
    Duration : 4 min 1 s
    Overall bit rate mode : Constant
    Overall bit rate : 262 kb/s
    Encoded date : UTC 2018-11-26 11:14:44
    Tagged date : UTC 2018-11-26 11:14:44
    Video
    Format : AVC
    Format profile : Baseline@L3
    Format settings : 1 Ref Frames
    Format settings, CABAC : No
    Format settings, RefFrames : 1 frame
    Codec ID : encv / avc1
    Bit rate mode : Constant
    Bit rate : 256 kb/s
    Width : 640 pixels
    Height : 360 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.044
    Stream size : 7.41 MiB (98%)
    Encryption : Encrypted
    MPD
    <?xml version="1.0" encoding="UTF-8"?>
    <!--Generated with https://github.com/google/shaka-packager version v1.5.1-c540e5a-release-->
    <MPD xmlns="urn:mpeg:dashchema:mpd:2011" xmlnssi="http://www.w3.org/2001/XMLSchema-instance" xmlnslink="http://www.w3.org/1999/xlink" xsichemaLocation="urn:mpeg:dashchema:mpd:2011 DASH-MPD.xsd" xmlns:cenc="urn:mpeg:cenc:2013" minBufferTime="PT2S" type="static" profiles="urn:mpeg:dashrofile:isoff-on-demand:2011" mediaPresentationDuration="PT241.88800048828125S">
    <Period id="0">
    <AdaptationSet id="0" contentType="video" width="640" height="360" frameRate="25000/1000" subsegmentAlignment="true" par="16:9">
    <Representation id="0" bandwidth="261831" codecs="avc1.42c01e" mimeType="video/mp4" sar="1:1">
    <ContentProtection value="cenc" schemeIdUri="urn:mpeg:dash:mp4protection:2011" cenc:default_KID="126f6601-3bcf-51a8-baca-ffeac0bfa6b1"/>
    <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed">
    <cencssh>AAAAMHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABAiCD EwMDcwOTg1SOPclZsG</cencssh>
    </ContentProtection>
    <BaseURL>70985.sd2_v_enc.mp4</BaseURL>
    <SegmentBase indexRange="1090-1373" timescale="25000">
    <Initialization range="0-1089"/>
    </SegmentBase>
    </Representation>
    </AdaptationSet>
    <AdaptationSet id="1" contentType="audio" lang="en" subsegmentAlignment="true">
    <Representation id="1" bandwidth="65378" codecs="mp4a.40.2" mimeType="audio/mp4" audioSamplingRate="32000">
    <AudioChannelConfiguration schemeIdUri="urn:mpeg:dash:23003:3:audio_channel_c onfiguration:2011" value="2"/>
    <ContentProtection value="cenc" schemeIdUri="urn:mpeg:dash:mp4protection:2011" cenc:default_KID="f6f869df-d2bd-5a6d-9644-4a09e10c9fbe"/>
    <BaseURL>70985.sd2_a_enc.mp4</BaseURL>
    <SegmentBase indexRange="952-1283" timescale="32000">
    <Initialization range="0-951"/>
    </SegmentBase>
    </Representation>
    </AdaptationSet>
    </Period>
    </MPD>
    Is this MPD contains decrypt key
  4. „Nothing within the mpd can directly be used with mp4decrypt."
  5. Originally Posted by ThunderRanger View Post
    Need access(login,pass)
    PM
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Please don't discuss how to download from payed streaming sites.
  7. <MPD mediaPresentationDuration="PT4M1.880S" minBufferTime="PT3.00S" profiles="urn:mpeg:dashrofile:isoff-live:2011" type="static" xmlns="urn:mpeg:dashchema:mpd:2011" xmlns:cenc="urn:mpeg:cenc:2013">
    <!-- Created with Bento4 mp4-dash.py, VERSION=1.7.0-613 -->
    <Period>
    <!-- Video -->
    <AdaptationSet maxHeight="1080" maxWidth="1920" mimeType="video/mp4" minHeight="360" minWidth="640" segmentAlignment="true" startWithSAP="1">
    <!-- MPEG Common Encryption -->
    <ContentProtection cenc:default_KID="adc230cb-c343-5de4-9ae6-f8c135ecdd79" schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc"/>
    <!-- Widevine -->
    Please anybody send code to apply for mp4decrypt.exe
  8. how to rip captions from zee5?
  10. Originally Posted by Sviests View Post
    e.g. streamlink:
    got Opening stream: 720p (hls-multi)
    is there any way to check if downloading, progress, speed etc?
