I wanted to do a fandub of lord of the rings and want it too be as good as it can be, so im trying to get the audio from the blu ray that are in 6 channels. I ripped it to mkv and removed the other languages and commentary tracks via handbrake and then extracted the audio to an mp3 file and there is only 2 tracks! Left and right and its not helfful for the difference between the two seems to only be that one has base. This is weird since the mkv file i ripped has no talking when i opened it, exept for background voices sometimes and faint voices sometimes, but keeping all music and sound effects. Probably because my earphones doesn't support 6 channel playback so some get lost. But still how do i translate that to audacity?
Results 1 to 24 of 24
With few rare exceptions, mp3 doesn't support more than 2 tracks. Exporting to that format is where you went wrong (assuming source was mutichannel).
Try ac3/dd.
Scott -
Thank you will try. Must find a program that converts to that format as well.
I used to use BeSweet and BeSweetGUI for the rare times I needed 5/6 wave files from multi channel audio.
Add the ffmpeg import/export plugin:
https://manual.audacityteam.org/man/installing_and_updating_audacity_on_windows.html#winff -
ffmpeg.exe should be in same folder as script or add PATH to ffmpeg.exe for example you can add bellow to your batch:
Assumption is that your ffmpeg.exe is in folder ffmpeg located on volume C: (you must modify this accordingly to your real ffmpeg location).Code:@set FF=C:\ffmpeg @set PATH=%FF%;%PATH%
[/QUOTE]ffmpeg.exe should be in same folder as script or add PATH to ffmpeg.exe for example you can add bellow to your batch:
Assumption is that your ffmpeg.exe is in folder ffmpeg located on volume C: (you must modify this accordingly to your real ffmpeg location).[/QUOTE]Code:@set FF=C:\ffmpeg @set PATH=%FF%;%PATH%
I don't understand what you are trying to say. How do i find the script to put in the same folder as ffmpeg, what is there to modify and what about it does not make it the real location? What is a batch and how do i add things to it? I need it open so i can convert the video to audio.Last edited by jooj; 19th Jul 2019 at 09:07.
You mean a graphics interface? I've never used it but...
https://forum.videohelp.com/threads/366212-FFQueue-%28ffmpeg-GUI%29-testing-feature-request-feedback
How to fix audio that jump from channel to channel?
By midts in forum AudioReplies: 2Last Post: 24th Apr 2017, 08:04 -
How to get a MP4 that have 4 audio channel from a file that have 2 audio
By marcorocchini in forum Newbie / General discussionsReplies: 15Last Post: 27th Dec 2016, 17:11 -
2 and 6 Channel Audio
By husaskin in forum AudioReplies: 7Last Post: 18th Jun 2016, 01:38 -
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 12:32 -
Sony Vegas Pro 11.0 - open 6 channel ac3 audio - codec???
By thesecretlie in forum Newbie / General discussionsReplies: 7Last Post: 10th Oct 2014, 12:26
