Hi there folks. This is my first time posting here.
Currently, I’m importing all of my family’s mini-DV tapes to digital. I’m using my dad’s 2011 MacBook Pro with iMovie on it to import the clips. The camcorder I’m using is the Canon VIXIA HV30 with a FireWire cable to import the footage to the computer. For the most part, the import process has been smooth.
However, on some tapes this weird glitch/effect happens, and it’s been hard for me to describe it. It’s like the tapes are split up into sections and everyone the effect happens, the tape acts like a new tape and resets how much footage it has left on there even though the tape has been used to record with before. This glitch has been preventing me from completing the importing process, as I’d like to have sound with these tapes.
The video/audio before the glitch happens is fine, but after it happens, the video imports, but no audio is attached to it. I’ve tried importing using QuickTime while letting the camera play through, no pausing but it didn’t work. I’m at a loss at what to do. I have a YouTube link to show you what the glitch looks like on the camcorder itself. If anyone can help me with this I’d appreciate it. Thank you!
https://youtu.be/yf9skgAyn-Q
Those are breaks in the recording (and possibly the camera was powered down in between.) As you notice, the timecode resets to 0. You have to manually start a new capture every time one of these happens. You cannot record across the break as the timecode is non-continuous.
Best guess -- whoever recorded the tapes wanted to watch a playback and then ran a little beyond the end to make sure they wouldn't overwrite previously recorded material. -
Pause the tape on the break. Hit capture on your computer, then hit play on the camera. (Most devices will start to capture once the signal is received -- your mileage may vary.)
Rule out the capture by seeing if the audio exists just playing the tape past the break and seeing if the audio plays out the cam's speaker. If so, some variation of the previous suggestion should work. If not, there's probably nothing you can do about it.
Scott -
Problems with importing mini dv tapes
By fine0023 in forum MediaReplies: 4Last Post: 7th Jun 2020, 14:42 -
digital video file to mini dv tape
By devdev in forum Video ConversionReplies: 10Last Post: 1st Jun 2019, 18:00 -
Importing NTSC tape on PAL camera?
By elangsru in forum MediaReplies: 1Last Post: 23rd Dec 2018, 13:32 -
Canon ZR950 mini dv importing into IMovie recording problem
By Fishn1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Apr 2018, 15:24 -
Audio out of sync when capturing AVI from Mini VHS Tape
By AvocadoTech in forum Capturing and VCRReplies: 2Last Post: 2nd Aug 2016, 21:29
