Hi everyone,
I still don't know if there's any benefit by converting video from 8bit to 16 bit in Avs or Vapoursynth!
That's why I would like to ask what is the benefit by converting video bit from 8 to 16 in Avs or Vapoursynth?
can anyone give me a good reason?
and does avs+ supports native 12 & 16 bit depth color?
thanx.
Often we do a lot of filtering (read: mathematical calculations) on the input in AviSynth/VapourSynth. With 16 bits precision we introduce less rounding errors in the filtering chain. These rounding errors can result in visible artifacts (e.g. banding). So to avoid these it may be beneficial to do out filtering in precisions higher than 8 bit. This depends on the type/amount of filtering you plan on doing and also your output format.
It does.
http://avisynth.nl/index.php/Avisynthplus_color_formats#Color_Format_Table
How to convert 12bit HEVC video file to 10-bit?
By batemanj in forum Video ConversionReplies: 4Last Post: 2nd Oct 2018, 13:34 -
How to Convert 10-bit to 8-bit with AviSynth?
By MrBiggles in forum Video ConversionReplies: 4Last Post: 6th May 2015, 04:38 -
How Can I convert a 24-bit W64 to 16-bit FLAC?
By eddman in forum Newbie / General discussionsReplies: 13Last Post: 27th Feb 2015, 10:36 -
Will video processing benefit from a card upgrade.
By sambat in forum Video ConversionReplies: 3Last Post: 8th Oct 2014, 23:17 -
How can I convert variable bit rate video without screwing up voice synch
By johnharlin in forum Video ConversionReplies: 3Last Post: 23rd Aug 2014, 06:23
