    May 2004
    Brazil
    Today I installed Audacity 2.3.1 to a recent Windows 7 installation I did on another SSD.
    Also installed FFMPEG and Lame.
    But when I try to open the audio tracks on an MKV file I get this error.
    What I'm missing or doing wrong?
    May 2004
    Brazil
    That's the one I downloaded, of course.
    May 2004
    Brazil
    And it's not working.
    Should I install another Audacity version?
    Mar 2008
    Open the video file in mediainfo and set it to view > text. Put the info here in this thread
    Have you tried dragging any other video files into Audacity - do they work?
    May 2004
    Brazil
    They always worked in other Audacity installations I have done, no problem at all.
    This time I had to install Vistual C+++ again and another program separately, because Audacity refused to run at all. That had never happened before.
    Then I installed FFMPEG, the one specified for Audacity, but I get that message.
    I just checked on my other SSD, and it was 2.3.1 too, so now I don't know what might be happening.
    I have just tried another video file, and it also denied opening.
    May 2004
    Brazil
    OK, problem solved.
    My fault. I had forgotten one step, which is going to Edit > preferences > libraries, and then selecting where FFMPEG and LAME directories were located.
    Now the mkv file opens fine in Audacity.
