Have you ever thought about transferring(physically move) the VHS tape to the S-VHS cassette(or to create the right hole in the VHS cassette) and playing it in an S-VHS VCR that read the cassette, tape as S-VHS(probably) ? Maybe someone did and/or saw such action and comparison and knows what the effect is ?
I think that maybe it would just make a bigger grain because of the higher resolution of reading the tape ? But the effect would be satisfactory for some - better than reading from this tape in the original as VHS. I don't know.
From the theory I know that what is written on the tape is already saved and more can not be extracted, but maybe in practice it looks different.
"[...] S-VHS improves luminance (luma) resolution by increasing luminance bandwidth.[2] Increased bandwidth is possible because of increased luminance carrier from 3.4 megahertz (MHz) to 5.4 MHz. Increased luminance bandwidth produces a 60% improvement in (luminance) picture detail, or a horizontal resolution of 420 vertical lines per picture height – versus VHS's 240 lines. [...]"
"[...] In order to take advantage of the enhanced capabilities of the S-VHS system, i.e., for the best recordings and playback, an S-VHS VCR requires S-VHS video tape cassettes. These have a different oxide media formulation for higher magnetic coercivity. S-VHS video cassettes are sensed and identified by the video cassette recorder via a specific internal profile within a hole in the underside of the S-VHS video cassette body.
Videophiles were the first to theorize that since the only distinguishing feature of an S-VHS tape is a small 3 mm hole on the underside of the video cassette, it should be possible to use more common and inexpensive VHS tapes by duplicating that hole. However, S-VHS cassettes also contain a higher grade and coercivity of tape stock to effectively record the higher video bandwidth offered by S-VHS. [...]"
Source of quotes: https://en.wikipedia.org/wiki/S-VHS
Comparison of cassettes differences in VHS, S-VHS, D-VHS systems: https://upload.wikimedia.org/wikipedia/commons/4/4e/VHS_tape_identification.jpg
S-VHS players already play VHS tapes.
Recordnig S-VHS on VHS tapes has always been possible. In the old days, you just drilled or melted holes in the clamshells. Then S-VHS-ET came out from JVC, and drilling/melting needed. I recorded tons of S-VHS-ET on high grade TDK and JVC tapes.
The main difference in VHS and S-VHS blanks were tape stock. You got more dropouts with VHS tapes, as it wasn't intended for the resolution.
I'd never convert VHS to S-VHS, not then or now. Analog generation loss.Last edited by lordsmurf; 16th Jul 2019 at 15:10. Reason: typo
A VHS recording on VHS tape won't magically become S-VHS level/quality due to the shell. It'll just read the signal and decode it.
The shell just flags the VCR to accept a higher bandwidth signal. But if the signal ISN'T higher bandwidth anyway (as that is not how it was recorded), it'll decode it as it normally would.
WASTE.OF.TIME.
vhs tape will NOT move through vhs recorder at all
By tepeco in forum RestorationReplies: 52Last Post: 24th Oct 2022, 13:31 -
Is a UK PAL video tape compatible with a continental Europe PAL VHS/S-VHS p
By arjaydavis in forum Capturing and VCRReplies: 7Last Post: 21st May 2019, 04:38 -
vhs tape question, 1/2 tape is fine and 1/2 way thru gets lines
By tomthetank in forum Newbie / General discussionsReplies: 8Last Post: 13th Jan 2019, 08:14 -
standard VHS tape in S-VHS cassette
By smartel in forum Newbie / General discussionsReplies: 8Last Post: 27th Dec 2018, 22:28 -
vhs tape cleaner
By godai in forum Newbie / General discussionsReplies: 9Last Post: 9th Apr 2016, 18:10
