Some codec when transfering AVCHD video files into computer fom much smooth editing in Pemiere or Vegas?
QUALITY HAS A NAME
visually lossless - cineform, dnxhd, hqx, prores (faster on a mac if using adobe). Cineform is probably the "best" overall for speed/quality on a PC . daniel2 in newer premiere versions if you have a good GPU is probably the fastest
lossless - magicyuv, utvideo
(but "lossless" yuv codecs are converted to RGB in vegas and premiere, so they aren't truly "lossless" . The exception is x264 lossless in newer premiere versions, but the scrubbing "performance" of I-frame , tune fast decode isn't very good)
alternatively, you can look at proxy editing workflows. Basically you edit a smaller resolution version, swap back on final render.
Editing AVCHD-file and uploading it to youtube HD
By ConvertKonvert in forum Newbie / General discussionsReplies: 2Last Post: 22nd Sep 2018, 05:53 -
Splitting into 3, editing 1, can't rejoin bc private codec data don't match
By Travillion in forum EditingReplies: 57Last Post: 8th Aug 2018, 15:34 -
Editing AVCHD/MP4(Sony CX-405) in Windows XP
By pchan in forum EditingReplies: 6Last Post: 8th Aug 2018, 01:41 -
GPU for editing 4k videos / h.265 codec
By moglisco in forum EditingReplies: 2Last Post: 27th Jun 2018, 13:13 -
Basic AVCHD/MP4 editing (title/join) without reencoding ?
By webvan in forum EditingReplies: 15Last Post: 20th Aug 2014, 15:00
