So I have recently purchased an old Canon MV700 camcorder but I am struggling to get the computer to recognise when the camcorder is plugged in therefore not being able to transfer tapes.
I have purchased this (https://www.amazon.co.uk/eightNice-Firewire-Female-Adaptor-Convertor-Black/dp/B077D4WC...gateway&sr=8-1) & (https://www.amazon.co.uk/kenable-Firewire-Cable-DV-OUT-Camcorder-Black/dp/B003OSPT0Q/r...gateway&sr=8-1) to connect the camcorder to the Mac, I am then using LifeFlix but it isn't recognising that there is a camcorder plugged in. Am I doing something stupid? Also what else could I buy to convert Mini DV tapes outside of the camcorder?
Any help is greatly appreciated and if anyone needs more information then please let me know!
Cheers,![]()
I hope you didn't fry your computer USB port or your camcorder, Those USB to firewire adapters are a scam to trap people with little to no knowledge in this kind of tech stuff. There is no such adapter that converts USB to firewire or vise versa without a proper processing and a circuit board full of micro chips. You need a mac with firewire port or some sort of firewire to a whatever mac uses I believe thunderbolt or something like that.
It is important to read products reviews before you buy anything you are not familiar with, Almost every review of that product said it doesn't work. -
OMG that thing is a pure unadulterated scam! From the looks of it it is a straight through connector. But USB (most especially before v3) has little in common with FireWire, electrically and physically. Unbelievable! Why is it still on amazon?
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
This vid kinda explains the method now used
https://www.youtube.com/watch?v=Q15QjTTF8_I
Note tho that you are no longer transfering DV video but recording the stream via quicktime (that could be a reason why the mac does not recognise the camera but I guess not)
The adapters are available on Amazon but will set you back almost £30 for both. -
Wow - thanks for you info guys I didn't realise that adapter was a scam, cheers for the heads up.
Have hopefully ordered the correct pieces now so fingers crossed! -
The forum exists both to help the person who started the topic and anyone who is looking for similar help in the future.
So you can help by coming back if and when you have solved the issue.
Canon ZR950 mini dv importing into IMovie recording problem
By Fishn1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Apr 2018, 15:24 -
Canon HG20 Mini hot shoe question
By rdoty in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 14th Oct 2017, 17:49 -
Canon Mini DV ZR950 playback problem
By Kimble in forum Newbie / General discussionsReplies: 1Last Post: 22nd May 2016, 15:32 -
Lose recording details transferring VRO from mini DVD to Hard disk
By Perceptive1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 13th Mar 2016, 19:55 -
Canon XA20 Data Import Utility not capturing audio when transferring
By TenYearsGone in forum Newbie / General discussionsReplies: 1Last Post: 28th Sep 2014, 15:55
