Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Feb 2016
    Europe
    Original Blu-ray - 1:40:10.254
    MKV - 1:40:36
    I've tried with mkvtoolnix (split by parts based on timecodes) and no results.
    I want to cut the movie exactly at 1:40:10.254 but without re-encoding. Is that possible?
  2. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    When cutting with MKVtoolnix it will only cut at the end of one GOP and the start of another GOP, so it will cut approximately within ~300 frames (depends on encoding settings). There's a program called MKVcutter which tries to do what you want for x264/H264 video. Avidemux is also an option for what you want.
    Feb 2016
    Europe
    Thanks, avidemux seems to be the best, with mkvcutter I canít see milliseconds. Just one more thing, isn't there any way to start at 00:00:00,000? Once you feed avidemux with a video file it always starts at 00:00:00.083. Is there any reason? I hope it won't cause desynchronization if I decide to add an audio file (commentary track) to the resulting mkv file.
