Sony BDP-S370 Blu-Ray Player does not detect USB Drive and Portable hard disk...Both are the NTFS file system
Shows as Error Unknown Device.
Firmware Updated
I format to FAT32...Its was detected played movie via USB works fine.
But I need to Transfer 10GB Movie file to USB...In FAT32 file not transfer more than 4GB? What to do?
or
In case the change file system NTFS to FAT 32 without data loss?
or
Any Settings to do detect NTFS file system?
Why not detect NTFS file system?... Every one said NTFS will detect in other sites
you could try exFAT fomatting. it's about the only thing that might work. NTFS is proprietary and a license to use it must be bought by the manufacturers, most don't.
it only supports FAT - FAT32 format only - https://forum.blu-ray.com/showthread.php?t=161477 post #14
You don't it's not possible. Either re-encode it to something smaller,
or split it using mkvtoolnix and keep the same quality
Sony BDP-S1500 Blu-ray Player , play MKV MPEG2 on USB ?
By s8n in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Nov 2018, 21:49 -
Old firmware versions for Sony Blu-ray players BDP-S1500 & BDP-S1700 ?
By creakndale in forum DVD & Blu-ray PlayersReplies: 2Last Post: 23rd Oct 2018, 12:25 -
Sony BDP-S370...
By Paddy Coleman in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th May 2017, 11:41 -
Misleading info given on the Sony BDP-S7200 blu-ray player region-hack page
By mattdegu in forum DVD & Blu-ray PlayersReplies: 7Last Post: 27th Oct 2015, 05:59 -
How to transfer videos to the USB drive connected to Blu ray player
By batemanj in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Aug 2015, 16:07
