My downloads keep failing with an error message like this:
40.3% of 3.44GiB at 399.36KiB/s ETA 01:29:54ERROR: unable to download video data: [SSL: DECRYPTION_FAILED_OR_BAD_RECORD_MAC] decryption failed or bad record mac (_ssl.c:1748)
PS C:\WINDOWS\system32>
and I find I just have to restart the download again and again until I eventually get the whole thing.
Youtube-dl does continue from where it left off.
How can I get it to do the retrying itself?
This error is most common when you're behind a VPN or proxy,if so,try changing location.
I'm also shooting in dark here,does it help you if you add --no-check-certiicate to the command?
What are you trying to download? (the url). FFMPEG does have keep-connection-alive thing. -
I just changed the vpn to latvia
the url is https://youtu.be/ZQ_fz9EW5Iw?t=71
i didn't think to put the nocheck in, next time it stops i'll do that...
p.s. was thinking if youtube-dl doesn't have a switch for it then perhaps I should put it in a batch file in a loop somehow?Last edited by abrogard; 12th Jul 2019 at 05:34.
youtube-dl --no-part --external-downloader ffmpeg https://youtu.be/ZQ_fz9EW5Iw?t=71
See if adding --retries infinite and/or --socket-timeout 1 help in any way
Latvia fixed it. Download completed okay.
Thanks for the suggestions. Next time I'm downloading and run into that hassle I will try them out. What's the point of the ffmpeg thing? I thought youtube-dl used ffmpeg by default, no?
youtube Download
By cornemuse in forum AudioReplies: 4Last Post: 3rd Sep 2019, 21:51 -
How to Download a playlist with Youtube-DL
By ConverterCrazy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2019, 01:10 -
How to download from Youtube TV?
By sergeygrady in forum Video Streaming DownloadingReplies: 0Last Post: 22nd May 2018, 05:45 -
How to download from youtube tv which i have subcription .
By achy635 in forum Video Streaming DownloadingReplies: 1Last Post: 29th Apr 2017, 16:48 -
Inability to download Youtube video by Youtube Downloader HD
By jgp123 in forum Video Streaming DownloadingReplies: 9Last Post: 17th Nov 2015, 05:03
