3 movies were not playing through Mitsun Player.
Connect through USB portable hard disk
Pls suggest
Check with Media Info details given below...
Movie-1
Error Shows...Dongle Not Supported Play this file
General
Complete name : G:\Me - Romania\Me.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/mp41)
File size : 5.88 GiB
Duration : 1 h 23 min
Overall bit rate : 10.0 Mb/s
Encoded date : UTC 2018-05-17 12:55:36
Tagged date : UTC 2018-05-17 15:45:15
TIM : 00:00:00:00
TSC : 24
TSZ : 1
Video
Format : AVC
Format profile : Main@L4.2
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference : 4 frames
Codec ID : avc1
Source duration : 1 h 23 min
Bit rate : 9 704 kb/s
Width : 2 048 pixels
Height : 1 080 pixels
Display aspect ratio : 1.896
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.183
Stream size : 5.69 GiB (97%)
Source stream size : 5.69 GiB (97%)
Language : English
Tagged date : UTC 2018-05-17 12:55:36
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Variable
Nominal bit rate : 317 kb/s
Maximum bit rate : 470 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Source stream size : 190 MiB (3%)
Language : English
Movie-2
This movie playing Audio 1 with Russian...hearing both audio simultaneously like translating in the Russian language.
In pc working fine...In Mitsun Player while select audio 2 no sound,video was playing smoothly without audio
General
Complete name : G:\Hei - Mexico\Hei.mkv
Format : BDAV
Format/Info : Blu-ray Video
File size : 29.8 GiB
Duration : 1 h 44 min
Overall bit rate : 40.7 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
FileExtension_Invalid : m2ts mts ssif
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Codec ID : 27
Bit rate mode : Constant
Nominal bit rate : 35.0 Mb/s
Width : 1 920 pixels
Display aspect ratio : 16:9
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.703
Audio #1
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : 129
Bit rate : 192 kb/s
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Stream size : 144 MiB (0%)
Language : Russian
Service kind : Complete Main
Audio #2
Menu ID : 1 (0x1)
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Muxing mode : Stream extension
Codec ID : 134
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Language : Spanish
Movie-3
No Sound, Video plays smoothly with subtitles
General
Unique ID : 36475571767664043119791300586397427480 (0x1B70F089026E44012599138F7F22E718)
Complete name : G:\Inslt - Lebanon\Inslt.mkv
Format : Matroska
Format version : Version 4
File size : 9.83 GiB
Duration : 1 h 53 min
Overall bit rate : 12.4 Mb/s
Encoded date : UTC 2018-05-09 22:20:17
Writing application : mkvmerge v23.0.0 ('The Bride Said No') 64-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9
Video
Format : AVC
Format settings : CABAC / 5 Ref Frames
Format settings, Reference : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 10.9 Mb/s
Height : 808 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.294
Stream size : 8.64 GiB (88%)
Writing library : x264 core 155 r2901 7d0ff22
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=25 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=10926 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:0.80
Default : Yes
Forced : No
Audio
Format : DTS
Codec ID : A_DTS
Bit rate : 1 509 kb/s
Bit depth : 24 bits
Stream size : 1.19 GiB (12%)
Language : Arabic
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 1 h 45 min
Bit rate : 63 b/s
Count of elements : 1577
Stream size : 48.6 KiB (0%)
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:08:14.202 : en:00:08:14.202
00:16:30.198 : en:00:16:30.198
00:28:45.390 : en:00:28:45.390
00:35:48.063 : en:00:35:48.063
00:42:06.983 : en:00:42:06.983
00:51:51.400 : en:00:51:51.400
00:57:02.336 : en:00:57:02.336
01:04:15.727 : en:01:04:15.727
01:11:21.569 : en:01:11:21.569
01:21:27.341 : en:01:21:27.341
01:31:22.644 : en:01:31:22.644
01:37:26.340 : en:01:37:26.340
01:47:18.057 : en:01:47:18.057
Results 1 to 1 of 1
Leawo Blu-ray Player: Problems Playing Blu-Ray Discs
By devilcoelhodog in forum Software PlayingReplies: 11Last Post: 24th Mar 2017, 08:32 -
LG blu-ray player is stopping playing blu-ray discs
By mausinho in forum DVD & Blu-ray PlayersReplies: 2Last Post: 22nd Feb 2016, 09:55 -
Sony BDPS5500 Blu-ray Player VS Samsung BD-J5700 Blu-ray Player
By tarzan54 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Jan 2016, 20:51 -
Looking for inexpensive Blu-ray player with wide ranging subtitle support
By JeremyBrown in forum DVD & Blu-ray PlayersReplies: 4Last Post: 23rd Mar 2015, 17:24 -
Blu-ray player mkv support
By kyrcy in forum DVD & Blu-ray PlayersReplies: 8Last Post: 22nd Dec 2014, 14:37
