Had to do a clean install of OS (W10) and while I lost none of my data, it did lose all of my installed Codecs
There are several Codec packs listed here - anyone pack a good set to go with ? ........ will then only add others if called for.
I seem to recall that on of them installs a lot of garbage (K-Lite ?)
Never, EVER, install a code pack. All will install things you will never need and potentially slow your system.
All the codecs, players etc. you ever need can be installed individually. Takes a little more time but you save that in the long term. -
K-lite codec pack no codecs in C4D?
By rison in forum Video ConversionReplies: 3Last Post: 20th Dec 2016, 13:44 -
Help! K-lite codec pack won't load in VirtualDub
By Barb711 in forum Video ConversionReplies: 20Last Post: 8th Jun 2016, 09:05 -
Slow Video Playback After Installing K Lite Codec Pack
By bakonfreek in forum Software PlayingReplies: 7Last Post: 8th Jun 2016, 08:24 -
klite codec pack
By JekylHyde in forum Newbie / General discussionsReplies: 9Last Post: 21st May 2016, 17:02 -
Google develops the new VP10 codec to defeat the HEVC codec
By Stears555 in forum Video ConversionReplies: 11Last Post: 26th Sep 2014, 10:18
