Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. hello,
    when I encode 720p HD sources with 29,97 to BD compilant 720p sources I usually use changefps(59.94) in Avisynth and make a 720p59.94 x264 encode.
    This time time I have a 25fps 720p HD source so I want to go for the 720p50 specification but somehow changefps(50.00) doesn't work. I get an error and don't understand why this is a wrong divisor?
    There is also the possibility to not use the avisynth fps command and just go for a
    720p25, which (according to http://www.x264bluray.com/home/720p-encoding) doubles the framerate with the "--pulldown double preset".
    The encode works fine but plays with 50% more speed which is totally senseless.
    Any advice is appreciated
    thanks
    regards
  2. Always post your complete AviSynth script, x264 command, logs and error messages.
    Note that pulldown may not work correctly with all muxers/authoring softwares (tsMuxer may have problems)
    http://www.x264bluray.com/issues-with-certain-players
    Aug 2013
    Central Germany
    In general you should prefer either a framerate preset string ("pal_double") or a pair of numerator and denominator (50, 1) over a floating point number.
    And to exactly duplicate frames, there may be more reliable functions than ChangeFPS. I would guess: Interleave(last, last).AssumeFPS(50, 1)
  4. My avisynth script was
    AVCSource("..........dga")
    changefps(50.00)
    my x264 command line in simple x264 launcher:
    --bluray-compat --level 4.1 --keyint 50 --sar 1:1 --slices 4 --vbv-bufsize 30000 --vbv-maxrate 40000 --b-pyramid none --weightp 0 --colorprim bt709 --transfer bt709 --colormatrix bt709 --merange 24
    the error line in the x264 log was "error: Evaluate: System exception - Integer Divide by Zero"
    using changefps(pal_double)
    causes the error: don't know what pal_double means
    Aug 2013
    Central Germany
    You forgot the double quotes for string literals. See: http://avisynth.nl/index.php/FPS
    changefps("pal_double")
    Furthermore, DGAVCDec is outdated. Recommendable alternatives today are FFMS2 or L-SMASH Works. But as long as it can handle your sources, well ...
  6. x264 offer possibility to use pulldown 2:2 - no penalty on bitrate.
  7. Originally Posted by LigH.de View Post
    doesn't work either. "System exception - Integer Divide by Zero" with changefps("pal_double") as well
    Ok I can check those out but I didn't get any error messages with DGAVCDec. The indexing was fine as usual so I doubt this is the problem here
    Mar 2008
    Does the script open successfully in Virtualdub2 ?
