Is there an AviSynth counterpart to this VapourSynth plugin? https://github.com/IFeelBloated/Fix-Telecined-Fades I have no experience in VapourSynth and I don't really want to switch all my setup for this![]()
I would suggest pulling the smartfade() script out of AnimeIVTC. It will fix interlaced fades.
This is a little too complicated for me. I've tried the following, but I do not see any difference in the output
Code:Mpeg2Source("D:\Ripping\VOB\VTS_02_1.d2v", info=3, idct=5) AssumeTFF() P1=Trim(0,50).TFM().TDecimate() P2=Trim(51,0).TFM().TDecimate() ScriptClip(P1, "sep = SeparateFields() \ interleave(sep.SelectEven(), sep.SelectOdd()).Weave().DAA()") Prefetch(6) P1++P2 -
Why would you go through and find all of the interlaced fades manually when the script I told you about has automatic detection?
Code:function smartfademod(clip c, float "sfthr", bool "sfshow", int "cache") { global sfthr = default ( sfthr, 0.4 ) # Threshold for fade detection. show = default ( sfshow, false ) # Displays luma difference between fields without processing anything. cache = default ( cache, 10 ) # Cache the frames to help seeking and other functions requesting many frames show ? scriptclip(c, "subtitle(string(abs( separatefields().selectodd().averageluma() \ - separatefields().selecteven().averageluma())))") : \ scriptclip(c, "sep = separatefields() \ avg = sep.selectodd().averageluma() - sep.selecteven().averageluma() \ abs(avg) > sfthr ? interleave(sep.selecteven(),sep.selectodd()).weave().daa() : last") cache<0 ? last : last.RequestLinear(8, cache, 5, false, false) return last }
Help with telecined cartoon that has combing/ghosting issues on encodes.
By Vitality in forum DVD RippingReplies: 12Last Post: 22nd Nov 2020, 12:52 -
Source is heavily compressed, and telecined.
By attackworld in forum EditingReplies: 2Last Post: 31st Jan 2019, 07:55 -
I cannot tell if this clip is Telecined or not...
By Lathe in forum RestorationReplies: 20Last Post: 7th Nov 2016, 00:41 -
Deinterlacing inverse telecined video
By Colek in forum Video ConversionReplies: 4Last Post: 9th Aug 2016, 08:51 -
Advice for hard telecined, variable framerate DVD?
By xAlienxx in forum DVD RippingReplies: 16Last Post: 16th Dec 2014, 16:26
