So I'm trying to do hardsub a srt subtitle with XVID4PSP right?
Video using MPEG4 2-Pass Size, Audio is Copy. Output to MKV container.
Instead, it just screamed error every time at 97% mark.
I can give full log if you want.Code:Error: ffmpeg version v0.8b2-55-gd780623, Copyright (c) 2000-2011 the Libav developers built on Jan 16 2012 06:34:56 with gcc 4.6.2 This program is not developed anymore and is only provided for compatibility. Use avconv instead (see Changelog for the list of incompatible changes). Input #0, avs, from 'D:\Temp\0011.avs': Duration: 02:01:49.35, start: 0.000000, bitrate: N/A Stream #0.0: Video: rawvideo, yuv420p, 1920x1040, 574503 kb/s, 23.98 tbr, 23.98 tbn, 23.98 tbc Stream #0.1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s [buffer @ 03851148] w:1920 h:1040 pixfmt:yuv420p Output #0, avi, to 'D:\Temp\0011.avi': Metadata: ISFT : Lavf53.19.0 Stream #0.0: Video: mpeg4, yuv420p, 1920x1040, q=2-31, pass 1, 1879 kb/s, 23.98 tbn, 23.98 tbc Stream mapping: Stream #0.0 -> #0.0 Press ctrl-c to stop encoding ffmpeg version v0.8b2-55-gd780623, Copyright (c) 2000-2011 the Libav developers built on Jan 16 2012 06:34:56 with gcc 4.6.2 This program is not developed anymore and is only provided for compatibility. Use avconv instead (see Changelog for the list of incompatible changes). Input #0, avs, from 'D:\Temp\0011.avs': Duration: 02:01:49.35, start: 0.000000, bitrate: N/A Stream #0.0: Video: rawvideo, yuv420p, 1920x1040, 574503 kb/s, 23.98 tbr, 23.98 tbn, 23.98 tbc Stream #0.1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s [buffer @ 019eaa50] w:1920 h:1040 pixfmt:yuv420p [mpeg4 @ 01a62268] [lavc rc] Error: bitrate too low for this video with these parameters. Output #0, avi, to 'D:\Temp\0011.avi': Stream #0.0: Video: mpeg4, yuv420p, 1920x1040, q=2-31, pass 2, 1879 kb/s, 90k tbn, 23.98 tbc Stream mapping: Stream #0.0 -> #0.0 Error while opening encoder for output stream #0.0 - maybe incorrect parameters such as bit_rate, rate, width or height
What did I miss? Should I not use 2-Pass Size thing? I do want to make it smaller for reasons.
This is my first time hardsubbing something and also my first time using XVID4PSP since a long time.
Any help is appreciated. Thanks!
Results 1 to 1 of 1
XviD4PSP form 13.10,2017 Runtime error
By Micky in forum Video ConversionReplies: 1Last Post: 13th Oct 2017, 15:29 -
Xvid4PSP (v5.10.346.0) cannot find Avisynth
By Taizenshū in forum Newbie / General discussionsReplies: 3Last Post: 25th Dec 2016, 10:17 -
xvid4psp only shows error now!
By galazul in forum Video ConversionReplies: 3Last Post: 28th Jul 2016, 15:08 -
Cant one MP4 video, error XviD4PSP 5
By adriannx in forum Newbie / General discussionsReplies: 1Last Post: 25th Dec 2015, 13:47 -
XviD4PSP Encoding Size
By Kick Drummer in forum Video ConversionReplies: 4Last Post: 29th Nov 2015, 18:37
