Hi
I want to convert some 200 hours of WMV-material to MP4 without too much quality loss. The original sources are both analog and digital video cameras captured long time ago with different types of hardware and partly using Movie Maker. Content is just family and hobby level so no high level of ambition. I´m using ffmpeg command version.
I did some simple testing with just "ffmpeg -i input.wmv output.mp4" and also tried adding -crf 18 - resulting in visible sharp lines compared to the wmv-files. With the -crf 18 addition the lines were a bit less visible, but still annoying.
What are the obvious options added to the ffmpeg-command to make these lines go away without increasing file size (too much)?
Here are some facts from the -crf 18 try:
Stream #0:0(eng): Audio: wmav2 (a[1][0][0] / 0x0161), 48000 Hz, stereo, fltp, 128 kb/s
Stream #0:1(eng): Video: vc1 (Advanced) (WVC1 / 0x31435657), yuv420p, 720x576, 4000 kb/s, SAR 16:15 DAR 4:3, 25 fps, 25 tbr, 1k tbn, 1k tbc
Stream mapping:
Stream #0:1 -> #0:0 (vc1 (native) -> h264 (libx264))
Stream #0:0 -> #0:1 (wmav2 (native) -> aac (native))
Before wmv to mp4 conversion:
[Attachment 49528 - Click to enlarge]
After - with the annoying lines:
[Attachment 49529 - Click to enlarge]
Regards, Per
Looks like artifacts from interlacing. Is the source interlaced?
Perhaps you should post a short clip of your source as-is to see the
best way to handle it -
Added deinterlacing using "-vf yadif" and that seemed to do the job. Thanks for the idea about interlacing. /Per
FFMPEG Conversion from MKV to MP4 returns a empty MP4 file?
By lolmaisine in forum Video ConversionReplies: 4Last Post: 6th Mar 2019, 07:45 -
ffmpeg to convert 4k/hdr10 to (i) h.264/10-bit/.mp4 (ii) h.265/10-bit/.mp4
By hydra3333 in forum Video ConversionReplies: 2Last Post: 10th Feb 2018, 19:49 -
ffmpeg AVpacket's header for WMV
By adamm in forum Newbie / General discussionsReplies: 1Last Post: 2nd Feb 2017, 14:41 -
MPG2Cut2 to FFMPEG MP4 vs FFMPEG MPG2 to MP4 AviDemux
By RedPenguin in forum Video ConversionReplies: 4Last Post: 29th Apr 2015, 12:16 -
ffmpeg remux wmv to mp4
By Russs in forum Newbie / General discussionsReplies: 3Last Post: 23rd Sep 2014, 05:49
