I have been playing with ffmpeg to convert h.264 and h.265 to ProRes and DNxHD. I would like the audio of the ProRes / DNxHD file to be PCM, as PCM works best with the free edition of Davinci Resolve in Linux.
All my source files are from these cameras:
1) Gopro Hero 7, and Gopro Hero 6
2) Panasonic DMC-G80 (DMC-G85)
I plug an external shotgun microphone, and sometimes a Lav microphone into the 3.5mm jack on the Pansonic G80. For the Gopro cameras I just use the on camera audio.
So with the above in mind, what setting should I use in ffmpeg? Should I use:
1) -c:a pcm_s16le
2) -c:a pcm_s24le
Or do I use some other setting for PCM audio in ffmpeg?
Sorry for the very basic question, but I'm not an audio guy!
Check which one works for you best - 24 bit is better than 16 bit thus i would try first pcm_s24le (later perhaps pcm_s24be) if this not work OK then try 16 bit..
ffmpeg error setting profile
By yukukuhi in forum Video ConversionReplies: 24Last Post: 9th Jul 2016, 23:51 -
encoding audio PCM in a MP4 container with FFMPEG?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2016, 16:03 -
ffmpeg: setting IDR frames option.
By Prathamesh in forum Video ConversionReplies: 10Last Post: 12th Nov 2015, 14:22 -
adpcm,pcm Encoders/Decoders and possible file extensions with ffmpeg
By alexander121 in forum AudioReplies: 3Last Post: 5th Feb 2015, 03:22 -
ffmpeg setting to convert AVCHD to HDV (mpeg2video)
By reko in forum Video ConversionReplies: 15Last Post: 8th Sep 2014, 10:03
