It's called Reverse.avs and it reads like this,
It works fine in VirtualDub 1.10.4 but not VirtualDub2. I keep getting the error,Code:AviSource("filename.avi") Reverse()
AVI Import Filter error: (Unknown) (80040154)
It works here, even with WAV audio included in the script. I'd bet your problem is the audio, whatever kind it is. What happens when you reverse it without the audio?
AviSource("filename.avi",False)
Reverse()
If that opens, maybe decompress the audio to WAV audio and try again. -
AVS script compression failure in VirtualDub2 / Lagarith RGB
By abolibibelot in forum Video ConversionReplies: 19Last Post: 20th Dec 2018, 02:07 -
why VirtualDub64 don't open the same .AVS script that virtualdub32 open?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 10th Mar 2017, 04:04 -
Need help with AVISynth script
By duffbeer in forum DVD RippingReplies: 13Last Post: 8th Sep 2016, 16:05 -
Best possible AviSynth Script
By Suwadith in forum Video ConversionReplies: 31Last Post: 10th Sep 2015, 06:43 -
Avisynth script help?
By PeterNL in forum Newbie / General discussionsReplies: 6Last Post: 10th Dec 2014, 11:35
