As the title says whenever i increase my playback speed the video plays normally for about a second then the next half second it slows down a bit then the framerate goes back up again, it does this constantly throughout playback, its as if the player is unsure of how fast to spit out frames so it spits out a lot but then it notices its putting out too many and then slows the video down to compensate for whatever playback speed was selected. Is there any setting i can change to fix this problem, i'm in the process of testing out VLC if it has the same issue, the VLC on my android plays the videos smoothly with increased playback speed.
i5-7200u
gtx940mx
8gb ram
512gb ssd
mpc-hc 1.8.6.5
madVR / evr renderer
	Just to demonstrate what i mean i opened fraps and played a video, fraps shows the video playing at a constant 24fps when on 1.0 playback speed, when i increase the playback speed to 1.2 for example, the framerate goes up to 30 but instead of staying there it constantly bounces between 28-31fps which is causing the choppiness, it should play at a single consistent framerate.
	Thanks man, seems you are right, i disabled ffdshow raw audio decoder and now its no longer choppy. I know ffdshow is old but it has an equalizer which i badly need, is there any good audio decoders that comes with an equalizer since LAV doesn't come with one.
	Windows' default drivers don't include an equalizer but if you download the full drivers from the manufacturer of the audio device (usually RealTek) you'll have one built into the drivers.
  can't fix choppy/stuttering Video PlaybackBy Gwar in forum Software PlayingReplies: 11Last Post: 8th Feb 2019, 19:47
  Choppy playback - MPC-HC - STRONG HardwareBy Retrogue in forum Software PlayingReplies: 4Last Post: 23rd Sep 2017, 07:05
  Potplayer - Audio distortion when increasing playback speedBy Spansme in forum Software PlayingReplies: 0Last Post: 23rd Nov 2016, 11:54
  Video playback issues in MPC-HC with madVR but not DXVA on second monitorBy FrozenClear in forum Software PlayingReplies: 2Last Post: 28th Aug 2015, 10:56
  Choppy video in MPC BEBy maxiu in forum Software PlayingReplies: 5Last Post: 7th Dec 2014, 10:22
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
