I converted a 7.1 audio to stereo WAV with eac3to.
The audio volume is good, except for parts where there are explosions or shooting, which are way too loud.
Is there a way to process the audio so that the normal parts remain unchanged,
and the loud parts get decreased in volume, so that the loudness becomes equal?
Think about it: an "EXPLOSION" is supposed to sound louder than "talking" (excepting micro-size or far away).
A gain compressor can change that balance, but there are interactions, so unless you know what you are doing you could make it worse in a multitude of ways.
Scott -
He's right, it's very easy to compress it to the point of distortion, making dialogue LESS understandable.
If your player has an audio eq, try dropping the lowest band in level. That's pretty effective with explosions, also that pounding bass you often hear when things are about tp get sinister. That drives me nuts.
How To Use Loudness Equalization?
By Russell18 in forum AudioReplies: 4Last Post: 13th Jun 2020, 04:15 -
How do I combine a MPV video file and WAV audio file into an AVI?
By robertazimmerman in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2019, 10:47 -
Loudness measure from RTP stream
By ghaffar3 in forum Newbie / General discussionsReplies: 0Last Post: 10th Oct 2018, 11:42 -
how do I use a loudness meter to set peak level to -12dB before capturing
By codemaster in forum AudioReplies: 2Last Post: 18th Mar 2017, 09:23 -
Replacing DVD Movie file with demuxed Mkv file while keeping original Audio
By DeusExMachinaN7 in forum Authoring (DVD)Replies: 5Last Post: 9th Oct 2016, 13:44
