I am using VirtualDub 1.10.4 32bit at the moment, just noticed in the log few plugins were not loading. Could be I messed it up by copypasting from other VDub versions but not sure anymore. Any way to fix it? The log:
Code:[!] Error loading plugin "FFMpeg output" from module avlib-1.vdplugin: Plugin requires a newer plugin API version (v12 > v10). [!] Error loading plugin "FFMpeg Lame MP3" from module avlib-1.vdplugin: Plugin requires a newer plugin API version (v12 > v10). [!] Error loading plugin "FFMpeg AAC" from module avlib-1.vdplugin: Plugin requires a newer plugin API version (v12 > v10). [!] Error loading plugin "FFMpeg FLAC" from module avlib-1.vdplugin: Plugin requires a newer plugin API version (v12 > v10). [!] Error loading plugin "FFMpeg ALAC (Apple Lossless)" from module avlib-1.vdplugin: Plugin requires a newer plugin API version (v12 > v10). [!] Error loading plugin "FFMpeg Vorbis (libvorbis)" from module avlib-1.vdplugin: Plugin requires a newer plugin API version (v12 > v10). [!] Error loading plugin "FFMpeg Opus (libopus)" from module avlib-1.vdplugin: Plugin requires a newer plugin API version (v12 > v10). [!] Error loading plugin "Caching input driver" from module avlib-1.vdplugin: Plugin requires a newer input API version (v8 > v4). [!] Error loading plugin "Caching input driver (images)" from module avlib-1.vdplugin: Plugin requires a newer input API version (v8 > v4). [!] Error loading plugin "Caching input driver (audio)" from module avlib-1.vdplugin: Plugin requires a newer input API version (v8 > v4). [!] Plugins: Failed to load "C:\VirtualDub-1.10.4\plugins32\Lagarith.vdplugin": Module "C:\VirtualDub-1.10.4\plugins32\Lagarith.vdplugin" does not contain VirtualDub filters. [!] Error loading plugin "Script Editor" from module scripted.vdplugin: Plugin requires a newer plugin API version (v11 > v10). [!] Plugins: Failed to load "C:\VirtualDub-1.10.4\plugins32\x264-10.vdplugin": Module "C:\VirtualDub-1.10.4\plugins32\x264-10.vdplugin" does not contain VirtualDub filters. [!] Plugins: Failed to load "C:\VirtualDub-1.10.4\plugins32\x264-8.vdplugin": Module "C:\VirtualDub-1.10.4\plugins32\x264-8.vdplugin" does not contain VirtualDub filters.
VirtualDub2 plugins
By foldbck123 in forum Newbie / General discussionsReplies: 14Last Post: 21st Nov 2018, 03:29 -
videohelp.com won't finish loading - and loading is VERY slow
By hydra3333 in forum FeedbackReplies: 61Last Post: 7th Oct 2016, 08:54 -
Problems loading plugins into AVISynth
By bvdd in forum Video ConversionReplies: 51Last Post: 20th Nov 2015, 07:15 -
Virtualdub plugins
By natty in forum Newbie / General discussionsReplies: 4Last Post: 18th Aug 2015, 12:43 -
Video Plugins
By holde in forum Newbie / General discussionsReplies: 3Last Post: 22nd Apr 2015, 02:08
