Hello All
Newbie here. Just bought a Pioneer BD-RE drive and I am currently using it to create blu rays of TV programs that I have recorded and TV series that I have been given as 720p MKV files with a nice menu etc.
When I open MultiAVCHD and create a blu ray with the off air TV shows (Peaky Blinders - BBC4 HD 1080p) it works fine. No problem there. I also converted Beatles Anthology DVD's to blu ray for my dad as 1 disk is better than 6. Also worked fine.
The problem I have at the moment is when I tried to create a blu ray from a 720p h264 mkv file. When I load the file in multiAVCHD it shows as red. Having looked on the web people are saying I need to transcode the file. I have tried this and the file turns green. MultiAVCHD goes through the motions and when it has finished it says there are no compatible files/folders processed and the AVCHD folder doesn't contain any files/folders. There is however a FFINDEX file in the same folder as my source folder.
The BBC off air recordings work fine and having checked the codecs etc in MKVToolNix the video codec is H264 in both the BBC recording and the 720p h264 mkv. Both are mkv files.
Also all H264 files that have been encoded by both handbrake and Vidcoder throw up the same error. I just did a check on this to see if re encoding would solve the problem. It didn't!
This is the script I get detailing the error:
[01:14:16] *** Encoding : One pass - content: [00:43:11]
[01:14:16] *** Encoding : x264 options: --preset veryfast -B 601 -I 48 --level 4 -i 8 -b 3 -r 4 -m 2 --mvrange 511 -A p8x8,i8x8 --ipratio 1.1 --pbratio 1.1 --vbv-bufsize 25000 --vbv-maxrate 20000 --qcomp 0.5 --threads auto --thread-input --aud --nal-hrd vbr --sar 1:1 --b-pyramid strict --slices 0 --weightp 0 --rc-lookahead 48 -o "c:\multiAVCHD\_TEMP\multiTEMP-20190706\S01E01.[1280x720-23.976].264" "c:\multiAVCHD\_TEMP\multiTEMP-20190706\20190706-011415-uncrop-running.avs"
[01:14:23] *** Speed : 8116.22 fps (elapsed: 00:00:07 - Realtime x 338.51)
[01:14:23] *** Transcoding failed!
[01:14:23] *** Check ffdshow/avisynth/haali (reinstall)!
[01:14:23] >>> Download links: http://multiforum.deanbg.com/viewtopic.php?f=7&t=17
[01:14:23] *** DEBUG: Try to play [c:\multiAVCHD\_TEMP\multiTEMP-20190706\20190706-011415-uncrop-running.avs] in MPC or other player, which supports AviSynth scripts and report the error to the author!
[01:14:23] tsMuxeR failed to process [G:\TV Shows\Forever\Season 1\S01E01.mkv]...
[01:14:23] No compatible folders/files processed...
What am I doing wrong?
Kind Regards
CityCentreFox
Results 1 to 1 of 1
Ripbot264 Convert UHD Blu-ray 4k to Blu-ray 1080p
By microhunt in forum DVD RippingReplies: 0Last Post: 23rd Dec 2018, 12:12 -
Help - Blu Ray Authoring with multiavchd issue
By sapruitt in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Mar 2018, 12:05 -
Burning 720p files to a blu ray disk to watch in HD
By Gil T Remnant in forum Authoring (Blu-ray)Replies: 6Last Post: 10th Apr 2016, 17:12 -
Best Quality encoding from 1080p to 720p & 720p to 720p in Xvid4PSP?
By Odie111 in forum Video ConversionReplies: 8Last Post: 9th Jan 2016, 17:42 -
Best multiAVCHD Blu-ray subtitle settings?
By hbenthow in forum SubtitleReplies: 0Last Post: 30th Dec 2014, 00:13
