I am converting 4K MKVs to 1080p to burn to BD-25s.
In Vidcoder I set the target size to 23100mb. That resulted in an output file of 19.6GB I wanted an output of 23.1gb.
So I set the size to 23.1 * 1024 = 23655. I ended up with an output file that was 26.1GB. (The bitrate was 25879).
Frustrated, I tried the bitrate to set the size. So I calculated (25879/26.1)*23.1 = 22905.
That resulted in an output file of 20.4GB.
Each attempt cooks my CPU for 7 hours. (CPU is I7-7900X @ 4.3GHZ with 32GB DDR4-3200 with a Corsair H115i Pro RGB cooler).
Obviously I'm doing it all wrong.
How can I get VidCoder to give me the output file @ around 23GB?
10940x with Creator X299 Motherboard, 32GB DRR4-3733, RTX 3080 Ti GPU
When you choose "Average bitrate" make sure to also select "2-pass Encoding"
and you should get a more accurate result -
Thanks for your reply
Sorry, I should have provided more information.
I always use 2-pass. It is definitely ticked, and turbo first pass is not ticked.
I've tried several presets HQ, Super HQ (1080p30, surround) etc.
I use H264 (x264) codec, I don't use NvENC (I'm more interested in quality than time, though 7 hours per encode is tedious)10940x with Creator X299 Motherboard, 32GB DRR4-3733, RTX 3080 Ti GPU -
I'm wondering if there is anything you should be setting that is affecting the encoders ability to
maintain the rate? This is beyond my experience, but there are some specific things used to
override the x264 command for blu-ray compatibility. Are you using any of these?
http://www.x264bluray.com/home/1080i-p
Other than that I don't know, see if you get further responses -
i wouldn't use 2 pass encoding. it's for when you want the encoder to make the video size as small as possible. at a bitrate of over 20,000 it's silly and wasting cpu time. there isn't really a good reason to have to "fill" the disc anyway. the difference visually between 22,000b/s and 24,000b/s isn't going to be noticeable by anyone even on a 10ft projector screen.
OK, so I'll try with 2-pass off.
All good and well to say that filling a disc is a waste of time, but I'm trying to get it to fit on the disk. 26gb doesn't fit on a 23gb disk. It's either <19gb or >23gb. I can't seem to find a collection of settings that will get me something in between. Of the 5 tests I've now done, 4 ended up >23.3gb.
Dropping a file size from 60GB to <19GB has got to have a noticeable impact on quality, surely?10940x with Creator X299 Motherboard, 32GB DRR4-3733, RTX 3080 Ti GPU
Bitrate and file size problem
By Aircraft in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2018, 19:36 -
Vidcoder, reducing bitrate results in larger audio stream. How?
By bizzybody in forum Video ConversionReplies: 2Last Post: 28th Feb 2018, 00:20 -
Embedding Subs with VidCoder size and settings
By HOK1N in forum SubtitleReplies: 2Last Post: 12th Aug 2016, 12:21 -
content bitrate vs Demuxed data size
By Karol in forum Video ConversionReplies: 8Last Post: 22nd Jun 2016, 21:40 -
Different file size and bitrate after muxing in MKVmerge
By gtx780 in forum EditingReplies: 1Last Post: 8th Jul 2015, 09:20
