While trying to transcode a rip with RipBot264 I'm encountering some problems that seem to have to do with the frame counts. The problem was initially discovered with an .m2ts file that was output from tsMuxeR (to downconvert the audio to .ac3) but I get the same result if I load the .m2ts file directly from the BD rip.
Video is H.264. The encoding settings window in RipBot264 shows FPS 29.97, Frames 45181, Duration 0:25:7.541, but if I look in the temp folder in the file 'video - Log.txt' it includes the line 'Video track 2 contains 37178 frames.', a difference of 8003 frames. Other files in this folder have the 45181 frame count. One of the 'video - Log.txt' files (the one from txMuxeR) has more than a thousand '[v02] Video overlaps for 28 frames at playtime 0:00:08. <WARNING>' messages (with varying frame counts and playtimes). The other (the one directly from the rip) has none of these but has the same 37178 frame count (and the same result described below).
When I play the resulting transcoded file, the entire video track has been compressed down to about 20:40 (37178/29.97 = 20:40.507), followed by more than 4 minutes of repeated content, while the audio and subtitles both play for the original 25:08 length, meaning that both quickly get way out of sync with the video, on the order of minutes by the end of the program.
I can play either of the aforementioned .m2ts files in VLC and both play the video content for the correct 25:07 length. Even the 'video.mkv' files in the RipBot temp folders play for 25:07. It seems only the transcoded output plays as 20:40. The issue seems to be that the transcoding process uses the 37178 as gospel rather than the 45181, losing more than four minutes of video. (I'm not having any issues with audio, subtitles, or chapter marks.)
Any suggestions what to do to get a transcoded video that plays for the correct length?
	No ideas? Are there any reports I could run on the original .m2ts file and post here that might be helpful?
 Maybe what's needed is to somehow "minimally repair" (but mostly just copy) the h264 video stream so that RipBot will recognize it as having all 25+ minutes of video content instead of losing nearly 4.5 minutes worth.
	For reasons I can't go into here, it has to be RipBot. I thought about trying another encoder as a matter of curiosity just to see if they encounter essentially the same issue. Also, I've successfully ripped and transcoded dozens of BDs and this is the first time I've encountered this particular issue. The ones I've encoded in the last week and a half since the original post here, I checked the frame counts in 'video - Log.txt' vs. 'info.txt' and they matched exactly.
 Mediainfo:
 General
 Complete name : G:\BDCopy\GSG_S2_D1\BDMV\STREAM\00101.m2ts
 Format : BDAV
 Format/Info : Blu-ray Video
 File size : 5.37 GiB
 Duration : 25 min 10 s
 Overall bit rate : 30.6 Mb/s
 Maximum Overall bit rate : 48.0 Mb/s
 Video
 Menu ID : 1 (0x1)
 Format : AVC
 Format profile : High@L4.1
 Format settings : CABAC / 4 Ref Frames
 Format settings, CABAC : Yes
 Format settings, Reference frames : 4 frames
 Codec ID : 27
 Duration : 25 min 7 s
 Bit rate mode : Variable
 Bit rate : 28.0 Mb/s
 Maximum bit rate : 39.0 Mb/s
 Width : 1 920 pixels
 Height : 1 080 pixels
 Display aspect ratio : 16:9
 Frame rate : 29.970 (30000/1001) FPS
 Color space : YUV
 Chroma subsampling : 4:2:0
 Bit depth : 8 bits
 Scan type : MBAFF
 Scan type, store method : Interleaved fields
 Scan order : Bottom Field First
 Bits/(Pixel*Frame) : 0.451
 Stream size : 4.92 GiB (92%)
 Color range : Limited
 Color primaries : BT.709
 Transfer characteristics : BT.709
 Matrix coefficients : BT.709
 Audio #1
 Menu ID : 1 (0x1)
 Format : AC-3
 Format/Info : Audio Coding 3
 Commercial name : Dolby Digital
 Muxing mode : Stream extension
 Codec ID : 131
 Duration : 25 min 6 s
 Bit rate : 640 kb/s
 Maximum bit rate : 4 569 kb/s
 Channel(s) : 6 channels
 Channel layout : L R C LFE Ls Rs
 Sampling rate : 48.0 kHz
 Frame rate : 31.250 FPS (1536 SPF)
 Bit depth : 16 bits
 Compression mode : Lossy
 Stream size : 115 MiB (2%)
 Service kind : Complete Main
 Audio #2
 Menu ID : 1 (0x1)
 Format : AC-3
 Codec ID : 131
 Duration : 25 min 9 s
 Bit rate : 640 kb/s
 Maximum bit rate : 2 805 kb/s
 Bit depth : 16 bits
 Text #1
 Menu ID : 1 (0x1)
 Format : PGS
 Codec ID : 144
 Delay relative to video : 10 s 944 ms
 Text #2
 Menu ID : 1 (0x1)
 Format : PGS
 Codec ID : 144
	I have seen in the past files with scan type MBAFF can cause this kind of problem.
 I'm not sure what mechanism Ripbot32 uses to open files if you open them directly;
 I've only ever used it when feeding it an AVIsynth script and have the script open the file -
 that way, I can control the source file filter
 Perhaps somebody who knows will chime inLast edited by davexnet; 13th Jul 2019 at 21:28. Reason: typo
  Trouble with DVD-Video compatible transcoding from 5:4 to 4:3By pauleck in forum Newbie / General discussionsReplies: 7Last Post: 21st Apr 2019, 10:29
  Muxing MKVs in MKVToolNix 31.0.0 loses video qualityBy safarian24 in forum Newbie / General discussionsReplies: 6Last Post: 3rd Mar 2019, 18:54
  FFMPEG transcoding gone down after few Minutes.By drpaudel in forum Newbie / General discussionsReplies: 0Last Post: 20th Sep 2018, 21:36
  Replacing last 5 minutes in mkv videoBy carlmart in forum EditingReplies: 11Last Post: 5th Mar 2017, 16:05
  split a video every 60 minutesBy RBCC in forum EditingReplies: 8Last Post: 26th Sep 2015, 15:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
