  1. I recently downloaded Van Wilder and it is in MPEG 1 format. With .mp3 audio at 29 frames per second. The data rate is 99 kbs and it is compressed using the DIVX codec. Whenever I try to burn this with Sonic it does allright, until the audio gets out of sync with the audio. Then I tried burning it with Ulead and the movie doesn't even show up, all you can hear is the audio. Then I tried converting it using TMPGEnc and no matter what method I use I always get a black screen in the preview with the end result being a black screen where you can only hear the audio. Any help or suggestions are in dire need, this thing has me stumped. By the way I forgot to tell you guys that the movie is perfectly visible when I play it on my computer.
    Wow Dude, Wow.
  2. you said its in mpeg format already . I think you should try nero just drag and drop
    We were all NEWBIES once and the only stupid question is the one that's not asked?
