Hi there,
I bought a blu-ray which is region A but only later I realized that I live in a region B country.
Since this movie is not available here, it would be nice if there was some way of converting it to a blu-ray of region B.
So basically what I have tried is using the backup option of MakeMKV to create the backup, and then create an ISO-image using imgburn and then burning it to a blu-ray.
However, both VLC-Player and my Blu-Ray Player (where I would like the movie to play) say that the disc is not compatible with my region. Changing the region in VLC seems to work though.
I have also discovered the program BDedit, which tells me that no region code can be found on the ISO.
Does anyone have any idea what I could do to playback my Blu-Ray on the BD-Player?
Best regards,
Deathkid
Building a computer specifically for backing up DVD & Blu-Ray, need advice
By Tank360 in forum Newbie / General discussionsReplies: 19Last Post: 3rd Mar 2018, 23:14 -
Leawo Blu-ray Player: Problems Playing Blu-Ray Discs
By devilcoelhodog in forum Software PlayingReplies: 11Last Post: 24th Mar 2017, 08:32 -
A little guidance in backing up blu-ray discs
By adrian2055 in forum Blu-ray RippingReplies: 3Last Post: 27th Oct 2016, 15:02 -
Looking to start backing up my prized Blu-Ray disk collection
By CloneMe in forum Video ConversionReplies: 9Last Post: 12th Jan 2016, 06:40 -
pioneer blu ray burner -want to make 1:1 copies of my blu ray movies
By Cool joe in forum MacReplies: 10Last Post: 10th Dec 2014, 22:31
