I've downloaded it and I am trying to convert srt to ssa file, but the issue is it does not show convert options which I need to convert file. I've downloaded multiple versions, but it still gives me the same result. It's like the window is partially chopped off. Can anyone tell me what problem is associated with it? Thanks.
[Attachment 49489 - Click to enlarge]
Results 1 to 21 of 21
This software was last developed in 2001. You can load a srt file into Subtitle Edit and save it as ssa or load it into Aegis etc etc... I tried it out and looks the same on my PC.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
I converted SRT to SSA file, but when I opened it on Virtualdub Subtitler, none of the subtitles show up on video.
What about when just playing the video with the subs? They have to be named the same, of course, something like Movie.avi and Movie.ssa. They don't even have to go together. That is, the subs don't have to go with that video. They only have to be named the same.
And what did you use to convert them? Maybe attach them here so someone can have a look. -
Take a look at those. I've set VDUB as output screen only.
[Attachment 49495 - Click to enlarge]
[Attachment 49496 - Click to enlarge]
[Attachment 49497 - Click to enlarge]
[Attachment 49498 - Click to enlarge]
[Attachment 49499 - Click to enlarge] -
That is not ASS/SSA.
In a text editor ASS looks something like:
Use Subtitle Edit or Aegisub to create proper ASS/SSA as suggested by netmask56.Code:[Script Info] ; Script generated by Aegisub 3.2.2 ; http://www.aegisub.org/ Title: Default Aegisub file ScriptType: v4.00+ WrapStyle: 0 ScaledBorderAndShadow: yes YCbCr Matrix: None [Aegisub Project Garbage] [V4+ Styles] Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, OutlineColour, BackColour, Bold, Italic, Underline, StrikeOut, ScaleX, ScaleY, Spacing, Angle, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, Encoding Style: Default,Arial,20,&H00FFFFFF,&H000000FF,&H00000000,&H00000000,0,0,0,0,100,100,0,0,1,2,2,2,10,10,10,1 [Events] Format: Layer, Start, End, Style, Name, MarginL, MarginR, MarginV, Effect, Text Dialogue: 0,0:00:00.75,0:05:00.00,Default,,0,0,0,,We must occupy
Thanks. Also, I'm trying to remove subtitles of video I've downloaded from Youtube by using subtitle remover, but it does not detect subtitles. Can you tell me what's wrong with it?
Thanks? That's all you can say? You wrote that you used SubResynch from VobSub to convert from SRT to SSA when you obviously didn't, or didn't do it correctly. As sneaker pointed out, those are not SSA subs.
You can forget trying to remove hard coded subs. Even if successful you'll leave a big and very ugly blur. If trying to replace them with new subs, it'll be better to just cover them with a black box. -
I used Subtitle Edit to convert into SSA file. It does work on Virtualdub, but when I typed any other random language in the script, that didn't show up. It seems like it only accepts English.
The example you showed is not ASS or SSA, it's simply a SRT with colour tags <font> etc
This is what a genuine ASS or SSA file looks like
Code:[Script Info] ; Script generated by Aegisub 3.2.1 ; http://www.aegisub.org/ Title: Default Aegisub file ScriptType: v4.00+ WrapStyle: 0 ScaledBorderAndShadow: yes YCbCr Matrix: TV.601 PlayResX: 1280 PlayResY: 544 [Aegisub Project Garbage] Audio File: From Beginning to End (1) (1).mkv Video File: From Beginning to End (1) (1).mkv Video AR Mode: 4 Video AR Value: 2.352941 Video Zoom Percent: 1.000000 Scroll Position: 25 Active Line: 28 Video Position: 5093 [V4+ Styles] Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, OutlineColour, BackColour, Bold, Italic, Underline, StrikeOut, ScaleX, ScaleY, Spacing, Angle, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, Encoding Style: Default,Arial,20,&H00FFFFFF,&H000000FF,&H00000000,&H00000000,0,0,0,0,100,100,0,0,1,2,2,2,10,10,10,1 [Events] Format: Layer, Start, End, Style, Name, MarginL, MarginR, MarginV, Effect, Text Dialogue: 0,0:00:00.00,0:00:00.00,Default,,0,0,0,, Dialogue: 0,0:01:24.43,0:01:26.42,Default,,0,0,0,,I was born with my eyes wide shut. Dialogue: 0,0:01:26.63,0:01:28.83,Default,,0,0,0,,Sure, everybody is born\Nwith their eyes closed. Dialogue: 0,0:01:29.03,0:01:33.63,Default,,0,0,0,,But mine were closed so tight,\Nthey formed wrinkles. Dialogue: 0,0:01:33.97,0:01:38.14,Default,,0,0,0,,I remained with my eyes closed\Nfor more than 2 weeks. Dialogue: 0,0:01:38.34,0:01:41.18,Default,,0,0,0,,My mother,\Ncontrary to expectations... Dialogue: 0,0:01:41.38,0:01:42.94,Default,,0,0,0,,didn't worry. Dialogue: 0,0:01:43.15,0:01:45.34,Default,,0,0,0,,She always said\Nthat when I was prepared... Dialogue: 0,0:01:45.55,0:01:48.38,Default,,0,0,0,,and when I was ready,\NI would open my eyes. Dialogue: 0,0:01:48.59,0:01:53.42,Default,,0,0,0,,It was like this,\Nin the very first days of my life... Dialogue: 0,0:01:53.62,0:01:56.72,Default,,0,0,0,,I learned the true meaning\Nof free will. Dialogue: 0,0:02:30.29,0:02:33.13,Default,,0,0,0,,Francisco was used to that ritual... Dialogue: 0,0:02:33.33,0:02:36.63,Default,,0,0,0,,but that day was different.\NWhile he stared at me... Dialogue: 0,0:02:36.83,0:02:39.00,Default,,0,0,0,,through the thick,\Nsoundproof nursery glass window... Dialogue: 0,0:02:39.20,0:02:42.66,Default,,0,0,0,,I without any reason... Dialogue: 0,0:02:42.87,0:02:47.11,Default,,0,0,0,,opened my eyes, and looked\Nstraight into his. Dialogue: 0,0:02:57.35,0:02:59.58,Default,,0,0,0,,Do you think it can swim? Dialogue: 0,0:02:59.79,0:03:01.42,Default,,0,0,0,,- No!\N- I fooled you! Dialogue: 0,0:03:01.63,0:03:04.59,Default,,0,0,0,,- I'm gonna throw him down!\N- No! Dialogue: 0,0:03:04.80,0:03:07.70,Default,,0,0,0,,Take the slippers off. Dialogue: 0,0:03:12.30,0:03:13.43,Default,,0,0,0,,Do you want it? Dialogue: 0,0:03:13.64,0:03:15.16,Default,,0,0,0,,- What's his name?\N- Basta! Dialogue: 0,0:03:15.37,0:03:19.40,Default,,0,0,0,,What a ridiculous name\Nfor a stuffed dog. Dialogue: 0,0:03:19.61,0:03:22.81,Default,,0,0,0,,- Mommy chose it.\N- She was messing with you. Dialogue: 0,0:03:23.01,0:03:25.71,Default,,0,0,0,,She told me it was\Nan "appropiate" name. Dialogue: 0,0:03:25.92,0:03:28.91,Default,,0,0,0,,It's "appropriate", Thomás!\NCome get me! Dialogue: 0,0:03:29.12,0:03:30.95,Default,,0,0,0,,- Give me my dog back!\N- No way! Dialogue: 0,0:03:31.16,0:03:32.21,Default,,0,0,0,,You two straight\Nto the shower! Dialogue: 0,0:03:32.42,0:03:33.95,Default,,0,0,0,,Lunch will be served\Nin 15 minutes. Dialogue: 0,0:03:34.16,0:03:35.65,Default,,0,0,0,,Rosa, take my dog\Naway from him! Dialogue: 0,0:03:35.86,0:03:37.59,Default,,0,0,0,,She can't.\NI'm faster than her. Dialogue: 0,0:03:37.80,0:03:38.89,Default,,0,0,0,,- No you're not!\N- Yes I am. Dialogue: 0,0:03:39.10,0:03:42.76,Default,,0,0,0,,And you won't catch me either!\NLook at this ugly dog! Dialogue: 0,0:03:42.97,0:03:46.33,Default,,0,0,0,,- Give it back!\N- Come and get it! Dialogue: 0,0:03:46.54,0:03:50.50,Default,,0,0,0,,Dad, get the dog from him! Dialogue: 0,0:03:51.18,0:03:54.41,Default,,0,0,0,,You two are making a mess. Dialogue: 0,0:04:11.93,0:04:18.39,Default,,0,0,0,,"FROM BEGINNING TO END"
I know this is an old thread, but I chose to import my subtitle file with AviSynth instead of VirtualDub. I use VS filter to import srt file, but the problem is that the subtitle doesn't show up when I import ssa file. Is there any problem with that?
Insert "info()" right before "TextSub()". What is the format? TextSub() does not support YV24 (planar 4:4:4 YUV).
[Attachment 49844 - Click to enlarge]
[Attachment 49845 - Click to enlarge]. Here are images for both srt and ssa. As I said before srt does work fine, but ssa doesn't as you don't even see the subtitle. By the way I don't even know why should I add Info() as it pop up the logo that I don't want to see. -
Attach the .ass/.ssa and the .avs file completely, not just screenshots of tiny parts.
Did you create these using Subtitle Edit? Try opening the .ssa/.ass file in a text editor and adding a new (empty) line at the very end of the file.Last edited by sneaker; 18th Aug 2019 at 06:02.
Yeah, it worked when I added a space at the end of each dialogue. Thanks for your help.
Youtube Transcript to SRT Converter
By Hikmet in forum ProgrammingReplies: 5Last Post: 30th May 2022, 04:03 -
3d subtitles don't regonise it at all - srt to all converter program
By fits79 in forum SubtitleReplies: 40Last Post: 9th Apr 2017, 06:31 -
Convert srt to ssa
By ssa_newbie in forum SubtitleReplies: 12Last Post: 15th Apr 2015, 14:23 -
Folder of Srt files, to SSA at once
By smokeweedevryday in forum SubtitleReplies: 4Last Post: 19th Dec 2014, 08:01 -
Subtitle Edit Convert SSA Subtitles To SRT Issues!
By kairukun in forum SubtitleReplies: 3Last Post: 14th Oct 2014, 02:58
