    Feb 2015
    Spain
    When I double click on the executable a window with this information comes out.
    DirectoryNotFoundException (2.0.2.4)
    No se puede encontrar una parte de la ruta de acceso 'C:\Users\Isabel\Documents\Edicion\Staxrip.2.0.2.4.x64\v4.7\Apps\Versions.txt'.
    System.IO.DirectoryNotFoundException: No se puede encontrar una parte de la ruta de acceso 'C:\Users\Isabel\Documents\Edicion\Staxrip.2.0.2.4 .x64\v4.7\Apps\Versions.txt'.
    en System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    en System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
    en System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
    en System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize, Boolean checkHost)
    en System.IO.StreamReader..ctor(String path, Encoding encoding)
    en System.IO.File.InternalReadAllLines(String path, Encoding encoding)
    en StaxRip.Package..cctor()
    No se puede encontrar una parte de la ruta de acceso = Unable to find a part of the path
    I can not do anything with the program
    Jun 2012
    Gurupi
    Import from one of the folders, or 4.7 or 4.8, the executables to the application root.
    Feb 2015
    Spain
    Thank you.
