I wanted to download https://www.videohelp.com/download/NeroAACCodec-1.5.4.zip from the download section to a linux machine of mine (which has no desktop environment, so shell only).
Problem is a simple:
won't do since it's redirected and a referer is added, so something likeCode:wget https://www.videohelp.com/download/NeroAACCodec-1.5.4.zip
has to be used.Code:wget https://www.videohelp.com/download/NeroAACCodec-1.5.4.zip?r=12345678
-> Is it correct that this is intended and I should download the binaries on a machine with a normal browser and then copy it to my other linux machine?
Cu Selur
I assume it is intended to disallow hotlinking from external sites (or e.g. some GUI author using videohelp as a download/update serverCode:
wget --referer https://www.videohelp.com/download/NeroAACCodec-1.5.4.zip https://www.videohelp.com/download/NeroAACCodec-1.5.4.zip
). I don't think they mind you downloading the occasional file to your Linux machine.
I didn't think is was to hinder me on Linux, just wanted to know whether this was intended or a bug.
Cu Selur
Ps.: Thanks for the '--referer'
Hi what about section VR players
By Bernix in forum FeedbackReplies: 13Last Post: 29th Oct 2018, 03:31 -
Adding a blur over a section?
By TheGlow in forum EditingReplies: 2Last Post: 10th Jun 2016, 13:02 -
Adding a silent section
By efiste2 in forum AudioReplies: 1Last Post: 2nd May 2016, 17:58 -
Is there a way to delete a section of a DVD
By blinky88 in forum Newbie / General discussionsReplies: 9Last Post: 15th Mar 2015, 10:31
