The main thing(s) I (used to) download from youtube are/were just for the music. Now its such a pita to d/l anything, in my experience.
Would there be an easy/easier way to just d/l the audio portion? (d/l mp3 or d/l & convert to)
In the past I have easily d/l'd music vids from them, but no more, , , , ,
I am not talking new or newer music, I'm talking '50's-'60's + early '70's rock. I'm livin' in the past! (I am 72 now)
-corne-
Yes, no, maybe, I don't know, Can you repeat the question?
URLs should better not be enclosed in quote characters though.youtube-dl --format bestaudio "url"
Thanx, I'll give it a try
-c-Yes, no, maybe, I don't know, Can you repeat the question? -
You can use an online service if you like:
https://www.onlinevideoconverter.com/youtube-converter -
Another online converter is savefrom, youtubeconverter and others
All is possible!
I watch movies -
Online converters constantly get broken or disappear (and are full of egregious ads if not using ad-blocking extensions), while youtube-dl has been consistently updated for years and is unlikely to vanish anytime soon.
To get more control, first type :
=> It works like that if the “youtube-dl.exe” file is in the same directory from which the command is launched in the command prompt, or in a directory included in Windows “PATH”. Otherwise it's required to type the full path, for instance, “"C:\CLI tools\youtube-dl.exe" -F ” (quotation marks are required if there is a space in the path).Code:youtube-dl -F [link]
This will list all the available formats. Usually the m4a audio is "140", so you then type :
=> The case is important : upper case -F just lists the available formats, while lower case -f actually downloads the specified format.)Code:youtube-dl -f 140 -o "H:\YouTube - %(title)s [%(id)s].m4a"
=> The “-o ...” part is optional, it allows to customize the file name with various available templates.
=> If it no longer works, it probably means that YouTube's layout has changed somehow, in which case updating youtube-dl with the command “youtube-dl -U” usually solves the problem.
A much more complex software which may be easier to use (graphic user interface), and is also regularly updated (at least its platform-specific plugins) : JDownloader2. It automatically checks the clipboard for relevant links, and lists whatever downloadable content it finds, and so for a YT link it includes the audio-only stream (m4a). But at some point it started to fail with many YT videos, so I stopped using it for those and now only use youtube-dl.
Or there are small programs which are just GUI layers for youtube-dl, which may be more “user friendly” but have limited options compared with the CLI.
Downloading Interview - Youtube
By devilcoelhodog in forum Video Streaming DownloadingReplies: 4Last Post: 11th Aug 2019, 12:42 -
Downloading best quality audio from youtube, and in general
By getwellsam in forum AudioReplies: 7Last Post: 5th Jun 2018, 17:37 -
downloading only part of a youtube video
By mvalmont in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2016, 17:17 -
downloading part of file youtube-dl
By BlueStone in forum Video Streaming DownloadingReplies: 6Last Post: 26th Jun 2015, 10:45 -
Downloading Purchased YouTube Video
By jramirez92 in forum Video Streaming DownloadingReplies: 4Last Post: 9th Mar 2015, 20:17
