  1. Is it possible to create anamorphic videos with TMPGEnc? And is it possible to use anamorphic videos in VCDs?
  2. do you mean widescreen
    We were all NEWBIES once and the only stupid question is the one that's not asked?
  3. Yeah, is it possible to encode anamorphic widescreen with TMPGEnc?
  4. if you are doing the ripping yourself I don't know how to do it.
    but if you downloaded a avi file and it's already in widescreen then you just leave your settings alone
  5. Anamorphic widescreen requires that your DVD player or TV will honour a non-4:3 display aspect ratio for your VCDs. Most widescreen TVs can probably be forced to do this. Your average DVD+TV combo probably cannot.
    Although you can set the DAR of a S/VCD to be 16:9 (e.g., like most anamorphic widescreen DVDs), your average DVD player may simply ignore it as S/VCDs only support (in the specs) a DAR of 4:3.
    Regards.
    Michael Tam
    w: Morsels of Evidence
