Hi
From time to time, amateur tough, I need to take some videos demonstrating my work and skill,
something like un-boxing a product but from my first person point of view (not showing my face)
Since it's amateur, I don't want to invest a lot on the equipment, 2k or 4k resolution is preferred, but not needed. However, I hope at least 720 or 1080p resolution. Any advice for budget-wise beginner?
In most cases, my video will be taken indoor.
Results 1 to 21 of 21
Point-of-view videos are often taken with an "action camera," like a GoPro. You strap it to your head so the viewer sees exactly what you are seeing.
You probably don't want to use a camera strapped to your head for POV unboxing videos. It will be jiggling around all the time. Mount it on a stand over your head, or over the product.
Go to youtube.com and search for "making unboxing videos". You'll find lots of helpful videos. Some people use a smartphone on a tripod sitting in front of them.
This depends quite a bit on which camera you are using. I have a Sony AS100 Action Cam. It has pretty decent stabilization built in, and is equivalent in most ways to a GoPro, except that (for its age) it produces better-quality video than the GoPros of that era. GoPros of that era had no stabilization built in and instead relied entirely on having a super-wide angle lens which, of course, minimizes the impact of the camera movement.
Here is a video I created with it which will demonstrate exactly what I posted above:
https://www.youtube.com/watch?v=2nwh50nWeuE
Note that the viewer sees exactly what I was seeing. My own impression is that the camera shake is not an issue.Last edited by johnmeyer; 27th Jun 2019 at 12:02. Reason: clarity
Oh Yes. I will not take "Action" video in most cases. In most cases I will take POV unboxing video
So you guys don't recommend Action camera like GoPro right?
The problem is I don't know what stand to be used for taking POV unboxing video from height? (which should not mount to the ceiling) -
Didn't you read what I wrote?? That (using an action camera strapped to your head) was exactly what I recommended, and it is also what I said I used for that video showing how to light chips for BBQ smoking.
If you instead want to follow some of the other advice already given, just get a tripod. Any sort of tripod will work. -
I just love my remote control for starting and stopping videos..
If you are zoomed out there is no jiggle at the beginning and end...
Mine came with the camcorder but you can buy after market remotes.. -
How can I take steady video like what I see from my eye? Example below
both hands free , but the video is stable (It doesn't show here). If they are using action camera strapped on the head, probably not stable because of head movement
gif upload -
Surely, you have heard of a tripod. Or, in the case of overhead shots, there are some inexpensive methods. Google "DIY overhead camera mount." Here's something to look at for starters...
https://www.diyphotography.net/three-ways-mount-camera-overhead-stills-video/ -
https://www.amazon.com/GorillaPod-Compact-Ballhead-Mirrorless-Charcoal/dp/B074WC9YKL/r...72873339&psc=1
There are a million tripods out there to pick from. -
It does?? I don't understand what you are trying to say.
Yes, I strapped it to my head.
Look, if you want perfectly stable video, just get a tripod and start doing your work. You really don't need to post any more here. We are going around in circles. -
still waiting for some real constructive recommendation instead of loser or haters
For example:
https://www.amazon.com/KobraTech-Cell-Phone-Tripod-Mount/dp/B06VXJMMQ3/
Note the video there shows the adapter in use with what appears to be that same tripod.
But a floor standing tripod or a mount that clamps onto the desk may work better for you, depending on your setup.
Taking screenshot in the exact size of the video always?
By vidblue in forum Newbie / General discussionsReplies: 7Last Post: 26th Jun 2019, 11:58 -
taking video, horizontally or vertically??
By kenny1999 in forum Newbie / General discussionsReplies: 24Last Post: 7th Aug 2016, 10:10 -
Beginner video editing software for Mac recommendation needed
By desidude in forum EditingReplies: 1Last Post: 27th Jul 2015, 01:53 -
Beginner Questions. Hoping to reach a professional level as video editor
By parker7d7 in forum Newbie / General discussionsReplies: 56Last Post: 6th Jul 2015, 11:11 -
good beginner video editor
By dfisher052 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 5th May 2015, 13:45
