Hi everyone. I am trying to convert all my old vhs tapes and put them onto dvd. I have borrowed a player which is a bush DVRHS02. My first issue was that I had some DVD-R and the machine would not recognise the disks at all. After a little research I realised that that type of disk is indeed not compatible. Luckily I found some DVD+R which the machine recognised so I began transferring our old family videos. Once done I played them back on the machine and they worked fine. I took an old new years eve party on disc to my dads to show him and tried to play it on his laptop. sadly it would not play. At home I tried the disk on a Ps4 and it would not play. I thought the disk were finalised by the machine as towards the end of the recording process it suggested that it had done this automatically. I am now trying to play the disk in the bush recorder and even that wont read the disk it burned itself....which I find odd. I could do with some help as my knowledge of doing this is not is obviously 0. Thankyou.
Cheap discs? There's only one reliable manufacture left, Verbatim. And only thier AZO discs are reliable. You won't find them on the shelf at your local Best Buy or Staples.
https://www.amazon.com/Verbatim-DataLifePlus-Inkjet-Printable-Surface/dp/B000A0CV9S/
https://www.amazon.com/Verbatim-4-7GB-Recordable-Media-Disc/dp/B003ZDNZSS/ -
My own experience of DVD+R is that you have to manually finalise the disk n the machine e immediately after the recording - not rely on what the screen tells you.
Even these disks you have recorded/played back on the recorder (I suspect without removing the disk) would require finalization. But if that finalization went ascrew, or as jagabo put it using cheap media, who knows what could happen. -
Thankyou for your replies. The disks I am using are TDK. The Bush machine does not have a function to independently finalise a disk. I have been through all the settings. I dont have the funds to buy disks and was hoping to be able to use the ones I had found stashed around my house. I have not tried it on my pc as yet but will do just incase. My other option is to record to a re-writable disk then transfer to pc as data. At least the footage will be upgraded to digital and saved for the future in some capacity. My pc is not great and crashes alot so I will have to be patient. I have a blue ray burner so I could at least then transfer the data onto 1 or 2 disks and maybe an external Hdd. I know this is a different ball game if i then wish to transfer to disk as video but the most important thing is to keep the footage long term. Does this sound like a better plan ?
http://3wires.net/manuals/BushHVRS02.pdfI have borrowed a player which is a bush DVRHS02.
Page 22 has a 'Finalize' menu.
Which DVD-recorder is prefered to transfer and record VHS tapes
By Desve in forum DVD & Blu-ray RecordersReplies: 21Last Post: 18th May 2020, 01:36 -
Problems playing back a DVD
By Basque in forum Authoring (DVD)Replies: 7Last Post: 23rd Jan 2018, 21:54 -
Weird stuff happening during VHS-to-DVD transfer
By Mac42 in forum Capturing and VCRReplies: 4Last Post: 22nd Nov 2015, 14:57 -
VHS to DVD / MP4 transfer
By PhilNorman in forum Video ConversionReplies: 3Last Post: 30th Oct 2015, 10:18 -
Proffessional VHS to DVD transfer
By efiste2 in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2015, 19:04
