Hi!
I have a Sony SLV-125 vcr that have some problems with rewinding tapes, hence I ask here in hope to get some help! The problem is that some tapes won’t rewind. In some cases I hear something spinning but there is no change on the timing display and no rewinding, in other cases it rewinds for a while before this behaviour starts and in other cases it works perfectly fine and rewinds as it should. There are no problems with playback or fast forwarding, I can also use the ”play rewind” which doesn’t give any of these symptoms. I’ve checked the belt which looks fine and I have cleaned the tape path, does anyone have any ideas what the issue might be? At this moment it’s mostly i mild nuissance but I’m afraid that the problems with the vcr might cause damage to my tapes.
Check the idler and clutch. Very commonly, the idler does not swing into proper contact with the reel table, or they are too worn/dirty for adequate friction. Clutches can wear out or malfunction so that not enough energy is transferred to the idler.
In general and been brief, sensors inside this devices needs feedback from some sensors to inform the main controller that everything is running ok, if one of them fails the rule of thumb it is to stop whatever the deck is doing. It might has some relation with the sensor it self, the communication lines the sensor uses that got cut because of a electrolytic capacitor leak, a electrolytic capacitor, etc.
This devices have too many moving parts, they need maintenance over the years and there is nothing you can do to fix it. -
Might be just the tapes that have the problem,do the tapes that rewind always rewind good?
I use these kind of items for my Beta and VHS machines. Might help you
https://www.ebay.com/itm/Kinyo-UV-520-VHS-Video-Tape-Rewinder-Auto-Stop-Eject-VCR-USED...IAAOSwXVpdEnfd
Sony SLV-T2000 Vs Sony EV-S9000E
By stunner21 in forum Capturing and VCRReplies: 0Last Post: 7th Nov 2018, 06:38 -
Need help unlocking Sony SLV-D550P
By Kopanaton in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Jun 2017, 22:55 -
Sony SLV-D380P DVD Player Hack
By West Coast in forum Newbie / General discussionsReplies: 0Last Post: 25th Jan 2016, 18:45 -
Sony SLV-D350-P DVD/VCR Combo Problem
By Abigal in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2015, 10:35 -
VHS to DVD - Turning off on-screen "STEREO" warning on Sony SLV X811 VCR
By 2prfm.com in forum Capturing and VCRReplies: 6Last Post: 18th May 2015, 13:44
