I'm trying to clean the heads on my Canon Vixia HV40. Yes - I know - tape based camcorders are history but I have lots of older video I shot with it so I still need to use it to get the footage into my computer.
I need to clean the heads but it's hard to get at the - uh - I forgot what you call it - but the large, round, silver, cylinder round thingy that the tape runs through. The problem is - even though the door thingy is open - it's hard to get at the round silver thingy.
I tried taking the door that holds the cassette off but there is a tiny screw in the hinge that I can't get out. The head of the screw is so tiny, my screwdriver just slides off when I try to turn the screw. I don't want to press too hard for fear of bending the hinge.
Any help will be appreciated.
Closed Thread
Results 1 to 30 of 32
I have a screwdriver that fits the screw - but I can't get the screw to turn. The screwdriver just slides out when I try to turn it. The problem is not the screwdriver - I have the right screwdriver - it's that the screw won't turn. The screwdriver is tiny and the right size.
If you don't know what you are doing just get a cleaning tape, especially with small portable tape machines.
https://www.amazon.com/Sony-Cleaning-Tape-Discontinued-Manufacturer/dp/B0000632H7/ref=...tronics&sr=1-4
Are you seriously not aware that cleaning cassette tapes do not always solve the blue screen problem? If you knew anything you would know that the heads need to be MANUALLY cleaned if the cleaning tapes fail and if you overdo the cleaning cassettes - they can damage your heads!!
You've already tried a cleaning tape without saying so? I'm sure in some cases a manual cleaning might be required but I've had great success with cleaning tapes in small/compact Video8 VCRs, similar to your miniDV.
You seem to be withholding information or simply refuse the cleaning tape idea.
Yes unlike someone trying to open up their tiny miniDV VCR for the first time. You are only supposed to play a cleaning tape for 10 seconds at a time. Maybe if you played it for hours and hours with a handful of new cleaning tape, you could cause some damage. But that's not what we are suggesting.
When the drum, heads, tape guides are dirty you can see it while you playback/record something. It's not a good practice to access the drum from the cassette side door for cleaning, you need full access to check the tape guides, capstan shaft, pinch roller and mecha.
Cleaning tape doesn't damage the heads that easy, a wrong type of cloth or printer type paper can do much more damage to the head than cleaning tapes.
Yes - the screen is blue - that's an indication that likely the heads are not clean. I have the blue screen issue thus I'm trying to clean the heads - already tried the cleaning tapes and that did not work.
"not a good practice to access the drum from the cassette door"
Agreed and it's also not possible to get at the heads unless you take that door off - thus my post.
I see all over youtube people cleaning their heads manually with a swab (yes I know they say a swab can cause tiny fibers to catch so better to use the paper "thing" designed specifically for cleaning heads) but w the Canon Vixia HV40 can't really get at the heads unless disassembling the cassette door.
Thanks for the replies but people - the problem is how to get the tiny screw in the door hinge UNSCREWED! I am using the tiniest 00 screwdriver but I just can't get the screw to turn. I am wondering how a shop gets a stuck screw out?
Blue screen it's not an indication of a dirty head, it means you have a poor signal that in general caused by tape misalignment with the drum. Many things can cause a tape misalignment like the tape guides, the rabbet on the lower drum, problem with the heads, etc.
To detect what is wrong it's necessary to read the RF signal from the heads, in case of misalignment the signal will look like this:
This is an indication that there is some problems with the guides or the lower drum rabbet, when everything is aligned the signal look like this:
In either case, there's nothing you can do at home to fix this, the camera need to be serviced by a professional.
Looks like the screw it's locked, possible glued. I'm not familiar with Canon decks but a professional would remove the door from the mecha without messing around with those screws.
Swabs are fine. Just don't use cotton. Use chamois swabs like the pros do.
If a new cleaning cassette didn't work, you may have bigger mechanical and/or electronic problems that are keeping the signal from coming through.
Another trick is to put in a cassette that's in good shape but doesn't have any recording you care about, then run it in forward and reverse search. That sometimes scrubs the gunk out of the heads.
Thanks for the info. Obviously you are very knowledgeable so I am not disagreeing w you but what I don't understand is that there are videos all over youtube about cleaning heads and nearly all of them show that when you get intermittent blue screen - that the problem is dirty heads that need to be cleaned.
Shortly before I got the blue screen, I had been inserting a tape into the camcorder but the door accidentally got closed BEFORE the tape mechanism was fully inserted/complete so that the tape was - for lack of a better expression - clamped in-between the door and the body of the camcorder. It was "mildly" clamped - not anything extremely forcefull. I wonder if that is what causes the blue screen?
I assume only a professional has the equipment to read the rf signals?
Canon does not service tape based camcorders anymore.
It would prob. cost at least $300 to have the camcorder serviced, even if I can find a place that would service it.
I can get a used one for $300 in ebay but then the heads are probably just as bad.
This is a real dilemma. I need a tape based camcorder inorder to be able to get my footage that I shot over the last 10 years into my computer. There is a lot of footage I never did anything with yet but intend to still use it.
"Another trick is to put in a cassette that's in good shape but doesn't have any recording you care about, then run it in forward and reverse search. That sometimes scrubs the gunk out of the heads."
Thanks, I'll try that - although another poster thinks the heads are out of alignment and that dirty heads are not the problem.
https://www.youtube.com/watch?v=yPQFSWZ02t0
Here's just one of MANY videos stating that blue screen means there is a problem w dirty heads that need to be cleaned??
So how is it that the problem could be misalignment?
I guess maybe a blue screen could indicate either or both?
Could be, but don't forget that EXCESSIVE INFORMATION does not necessarily equal CORRECT INFORMATION.
You mentioned a mishap with the door on a cassette before this all started. That could have occasioned excessive shedding, which would botch up the heads, but it could also be an indication that your player is mechanically out of whack. If you really want to get into this, you need to open it up and watch with the patience and determination of a jeweller.
What is the best way to clean 8mm/VHS heads?
By Vitality in forum Capturing and VCRReplies: 13Last Post: 6th Jun 2023, 14:35 -
Are these wipes safe to clean video heads with?
By Vitality in forum RestorationReplies: 7Last Post: 3rd Mar 2019, 02:47 -
Clean Betamovie dual-heads?
By Vitality in forum RestorationReplies: 0Last Post: 14th Feb 2019, 10:00 -
Found a new way to clean those small mini DV video heads.
By digicube in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 15th Feb 2017, 22:10 -
Canon Vixia G20 Help
By Rayhbez in forum Newbie / General discussionsReplies: 6Last Post: 21st Dec 2015, 16:49
