Results 1 to 12 of 12
  1. The following code runs OK from a Windows command prompt:
    ffprobe -select_streams v -i output.mpg -show_entries "frame=pkt_pts_time,pkt_duration_time,interlaced_frame" -pretty -print_format json -of json > output.mpg.json
    but I don't know Python or ffprobe well enough to get this Python script to work:
    import os, sys, subprocess, shlex, re
    from subprocess import call
    def probe_file(filename):
        cmnd = ['ffprobe.exe','-select_streams v', '-i output.mpg',' -show_entries, "frame=pkt_pts_time','pkt_duration_time','interlaced_frame'",'-pretty',' -print_format json',-of json > output.mpg.json]
        p = subprocess.Popen(cmnd, stdout=subprocess.PIPE, stderr=subprocess.PIPE)
        out, err =  p.communicate()
    #    print ("==========output==========")
    #    print (out)
        if err:
            print ("========= error ========")
            print (err)
    probe_file('test_pattern_709.mp4')
    Any help is appreciated.
    Thank you.
  2. I am PLEABS
    Apr 2018
    Earth
    Its pretty long time since i use FFMPEG stuff with python so forgive me if i make some mistake
    but pretty sure that cmnd var can be written directly by using single quotes to wrap the whole command
    cmnd = 'ffprobe -select_streams v -i output.mpg -show_entries "frame=pkt_pts_time,pkt_duration_time,interlaced_frame" -pretty -print_format json -of json > output.mpg.json'
  3. I'll give that a try, thanks.
  4. I got it to run without error but I'm not seeing the output I expect. It's not printing the format like it does when run as a batch file.
    #!/usr/bin/python
    cmnd = ''
    err = 0
      #print (filename)
    #  out, err =  p.communicate()
      out =  p.communicate()
      print (out)
    if err:
            print (err)
  5. I ried this and it worked, for windows:
    import subprocess
    import os
    def probe_file(ffprobe, filename):
        cmnd = [ffprobe , '-i', filename, '-show_entries' ,  'frame=pkt_pts_time,pkt_duration_time,interlaced_frame']  #'-print_format',  'json',  '-of',  'json'
        basename = os.path.basename(filename)
        with open(f'{basename}.txt', 'w') as log:
            p = subprocess.Popen(cmnd, stdout=log, stderr=subprocess.PIPE) #, shell = True #to not show pop up cmd window
            print(filename)
            if out:  #if you redirect output to text file , there is no output here, out is None
                print("==========output==========")
                print(out.decode('utf-8'))
            if err:
                print("========= error ========")
                print(err.decode('utf-8'))
    ffprobe = r'C:\path_to_ffprobe\ffprobe.exe'  #not having ffprobe in PATH
    input = r'C:\path_to_file\videofile.mp4'
    probe_file(ffprobe, input)
    for linux:
    import subprocess
    import os
        cmnd = ['ffprobe' ,  '-show_entries' ,  'frame=pkt_pts_time,pkt_duration_time,interlaced_frame',  filename]  #'-print_format',  'json',  '-of',  'json'
            print(filename)
            if err:
    input = /home/path_to_file/videofile.mp4'
    probe_file(input)
    linux has input file at the end
    you can also pass a directory for storing logs, so you can redirect it to other disk etc.
  6. I am PLEABS
    Apr 2018
    Earth
    import os
    import subprocess
    from pathlib import Path
    ffprobe = Path(r"\ffprobe.exe")
    def probe_file(_file):
        print("\non progress please wait...")
        cmnd = '"{0}" -hide_banner -select_streams v -i {1} -show_entries "frame=pkt_pts_time,pkt_duration_time,interlaced_frame" -pretty -print_format json -of json'.format(ffprobe, _file)
        a = subprocess.run(cmnd, stdout=subprocess.PIPE, stderr=subprocess.PIPE, universal_newlines=True)
        b = a.returncode
        if b == 0:
            print("=========output=========")
            c = open(Path(r"\output.mpg.json"), "w")
            c.write(a.stdout)
        else:
            print("\n=========error!=========")
            print(a.stderr)
    print("Enter your File path...")
    probe_file(Path(input()))
    edit: because of your question i have a good time by making this
  7. Thanks, Al - it works! Except it is printing the output as one big error message so I swapped the order of "out" and "err" on line 10:
    import subprocess
    import os
            print(filename)
            err, out =  p.communicate() # <- swapped order of "out" and "err"
            if err:
    ffprobe = r'ffprobe.exe'  #not having ffprobe in PATH
    input = r'test_pattern_709.mp4' #C:\path_to_file\videofile.mp4'
  8. Originally Posted by chris319 View Post
    it will work but it is a booby trap sort of, if it is swapped like that, you call out as err and err as out. It is quite normal that information is in stderr, so I'd leave it as err, except change comments to info, for example:
            if err:
                print("========= info ========")
    so this way it is clear that ffprobe puts info into stderr
  9. That's weird, but I've changed it as you have it.
  10. not sure what you mean, in your last example you have: err, out = p.communicate(), where it might rather be: out, err= p.communicate()
    from manual: communicate() returns a tuple: (stdoutdata, stderrdata)
  11. Here is the complete program, per your suggestion:
    import subprocess
    import os
                #print(filename)
            out,err =  p.communicate()
            if err:
  12. oh, ok, weird in a sense that info is in stderr. It helps to think of it something like two band channel. Out and err are just labels and devoleper channels whatever into whatever channel. Thanks to that, ffprobe can do a thing you want and still prints its own log. Or you can take out those labels and just use indexing, first item in that tuple has index 0, second 1:
            results = p.communicate()
            if results[1]:
                print(results[1].decode('utf-8'))
