  1. Hi all, hope someone here can help with the following question.
    I have 5x Multicast addresses, 1 for each of the 5 TV Networks in Sydney AU.
    I need to take 1 of the video + 1 of the audio channels and convert to RTSP output stream.
    Needs to be RTSP so it can be connected to a CCTV software.
    VLC does it, but audio and video get out of sync after several seconds.
    Is there any tools that will make this easier?
    1 of the Multicast addresses looks like this; (ffprobe result)
    Input #0, mpegts, from 'udp://@239.255.255.7:1234':
    Duration: N/A, start: 58699.418100, bitrate: N/A
    Program 1569
    Metadata:
    service_name : 10 BOLD
    service_provider: TEN Sydney
    Stream #0:24[0x3e8], 0, 1/90000: Unknown: none ([5][0][0][0] / 0x0005)
    Stream #0:25[0x3f2], 0, 1/90000: Unknown: none ([11][0][0][0] / 0x000B)
    Stream #0:26[0x3fc], 0, 1/90000: Unknown: none ([12][0][0][0] / 0x000C)
    Stream #0:14[0x202], 50, 1/90000: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv, top first), 720x576 [SAR 64:45 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0:11[0x2a0](eng), 76, 1/90000: Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 192 kb/s
    Stream #0:5[0x241](eng), 100, 1/90000: Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
    Program 1573
    Metadata:
    service_name : 10
    Stream #0:20[0x3ea], 0, 1/90000: Unknown: none ([5][0][0][0] / 0x0005)
    Stream #0:21[0x3f4], 0, 1/90000: Unknown: none ([11][0][0][0] / 0x000B)
    Stream #0:22[0x3fe], 0, 1/90000: Unknown: none ([12][0][0][0] / 0x000C)
    Stream #0:8[0x200], 50, 1/90000: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv, top first), 720x576 [SAR 64:45 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0:15[0x28a](eng), 76, 1/90000: Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16p, 256 kb/s
    Stream #0:10[0x240](eng), 99, 1/90000: Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
    Program 1574
    Metadata:
    service_name : TVSN
    Stream #0:13[0x206], 46, 1/90000: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv, top first), 720x576 [SAR 64:45 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0:27[0x2b2](eng), 77, 1/90000: Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16p, 192 kb/s
    Stream #0:28[0x3eb], 0, 1/90000: Unknown: none ([5][0][0][0] / 0x0005)
    Stream #0:29[0x3f5], 0, 1/90000: Unknown: none ([11][0][0][0] / 0x000B)
    Stream #0:30[0x3ff], 0, 1/90000: Unknown: none ([12][0][0][0] / 0x000C)
    Program 1575
    Metadata:
    Program 1576
    Metadata:
    service_name : 10 Peach
    Stream #0:16[0x3e9], 0, 1/90000: Unknown: none ([5][0][0][0] / 0x0005)
    Stream #0:17[0x3f3], 0, 1/90000: Unknown: none ([11][0][0][0] / 0x000B)
    Stream #0:18[0x3fd], 0, 1/90000: Unknown: none ([12][0][0][0] / 0x000C)
    Stream #0:12[0x204], 40, 1/90000: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv, top first), 720x576 [SAR 64:45 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0:19[0x2a9](eng), 76, 1/90000: Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16p, 192 kb/s
    Stream #0:7[0x242](eng), 98, 1/90000: Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
    Program 1577
    Metadata:
    service_name : SpreeTV
    Stream #0:0[0x208], 48, 1/90000: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv, top first), 720x576 [SAR 64:45 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0:1[0x2bc](eng), 73, 1/90000: Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16p, 192 kb/s
    Stream #0:2[0x3ec], 0, 1/90000: Unknown: none ([5][0][0][0] / 0x0005)
    Stream #0:3[0x3f6], 0, 1/90000: Unknown: none ([11][0][0][0] / 0x000B)
    Stream #0:4[0x400], 0, 1/90000: Unknown: none ([12][0][0][0] / 0x000C)
    Program 1572
    Metadata:
    service_name : 10 HD
    Stream #0:6[0x1ff], 104, 1/90000: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 50 tbr, 90k tbn, 50 tbc
    Stream #0:23[0x289](eng), 59, 1/90000: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 448 kb/s
    Stream #0:9[0x23f](eng), 98, 1/90000: Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
  2. Desperate, please help...
