I have a couple avi & mp4 files that have separate english & russian language tracks. It seems the russian voice dub is the default one. I tried burning one to DVD with Nero 7 but it had the russian dub over the english only. Is there anyway I can convert or burn it with just the english track?
Are you SURE you have two different audio tracks? Have you seen these two audio tracks in software?
VirtualDubMod can resave AVIs with your choice of audio. Once you've opened an AVI, the audio streams can be found under the Streams menu.
Be sure to select "Direct Stream Copy" as the video processing method under the Video menu before saving the new version.
Mux audio tracks inside in avi file
By Igniz in forum AudioReplies: 27Last Post: 1st Oct 2017, 19:44 -
DVD authoring with [Language Menu] for each [Language Audio]
By Meem in forum Authoring (DVD)Replies: 6Last Post: 23rd Sep 2017, 04:32 -
How to play a VCD with dual language tracks?
By guy24s in forum Authoring (VCD/SVCD)Replies: 7Last Post: 1st Sep 2017, 04:49 -
Burn MKV file with audio tracks to DVD on Mac
By crissrudd4554 in forum MacReplies: 21Last Post: 21st Mar 2015, 01:09 -
Question: How To Change Audio Tracks in AVI file?
By abrogard in forum Newbie / General discussionsReplies: 10Last Post: 8th Sep 2014, 07:34
