Hi,
I'm using Subtitle Edit to extract dvb subtitles from from .ts files.
When I Open the .ts file in SE, I export to "Blu-ray sup", then I change the Video resolution to "1080p (1920x1080)" and change align to "Center" and then "Export all lines".
I have many videos which I need to extract their subtitles and this way of extracting the subtitles is really consuming time and require a lot of user intervention.
I was looking for a way to automate the process with the preferences I'm choosing, or processing many subtitles at once.
Subtitle Edit command line seems to be a convenient solution, but the issue is that it seems that .ts files are not supported as input files.
When I try the below command:
I'm receiving the below error message: input file too large!Code:SubtitleEdit /convert "E:\Videos\Test.ts" Blu-raysup
Appreciate any suggestions to resolve this issue with SE or propose any other solution that might help me.
Results 1 to 1 of 1
Extract subtitles from MPEG-TS-file (DVB Subtitle & Teletext) using ffmpeg
By DeafYakuza in forum SubtitleReplies: 8Last Post: 13th Jun 2019, 13:40 -
Any command line tool for windows to edit MP4 metadata without remuxing?
By dothrakihorde in forum EditingReplies: 7Last Post: 16th Aug 2018, 18:00 -
Command line tool to extract wma from wmv?
By EdenResident in forum Video ConversionReplies: 7Last Post: 10th Aug 2018, 02:42 -
Best way to edit DVB TS, extract Subs, fix Aspect Ratio and output to Mpeg?
By Gibson's Squares in forum EditingReplies: 1Last Post: 9th Aug 2018, 18:35 -
Extract subtitles from MPEG-TS-file (DVB Subtitle) using ffmpeg
By T-buch in forum Video ConversionReplies: 22Last Post: 12th Mar 2017, 05:19
