I used DGIndex to create a DV2 file. I'm going to use VirtualDub to create an AVI. I have 3 audio files. Which on is best for an AVI?
VTS AC3 T01 2_0ch 192Kbps 48KHz.wav
VTS AC3 T01 2_0ch 192Kbps DELAY 0ms.ac3
VTS T80 2_0ch 192Kbps DELAY 0ms.ac3
	It's a D2V file. You only got one audio from DGIndex, right? Use that one.
 By feeding it an AviSynth script? If not you won't be using VDub as it doesn't accept VOB or D2V input directly.I'm going to use VirtualDub to create an AVI.
	I had used DVD2AVI before DGIndex so I ended up with multiple files. The D2V file created by DVD2AVI ends up unreadable. DGIndex did give me one AC3 file.
 When I open the AC3 with VirtualDub I get the "No audio decompressor" error. How do I fix this?
	Hybrid is better yet. Want my help? Ask here! (not via PM!)
	I tried the AC3 ACM Codec but I received an error during installation. I installed AC3Filter and now I'm able to open AC3 files directly in VirtualDub.
  Converting from AVI to MP4 H264 Multichannel Audio, InterlacedBy Nedo in forum Video ConversionReplies: 31Last Post: 6th Jan 2017, 18:34
  Fastest way converting avi with ac3 audio to aac/mp3?By manugiggs in forum Video ConversionReplies: 2Last Post: 23rd Sep 2015, 12:08
  New bie needs help in converting audio track of VOBBy charlieho in forum Video ConversionReplies: 19Last Post: 2nd Jul 2015, 00:08
  Batch converting DV-AVI type 2 to DV (Raw?) for MacBy jehomme in forum Video ConversionReplies: 24Last Post: 23rd Feb 2015, 13:55
  Trouble reading VTS_01_1 VOB file when converting to AVIBy LouB in forum Video ConversionReplies: 2Last Post: 8th Aug 2014, 07:21
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
