  1. Hi Friends,
    How can I use the loudness equalization feature in windows? Thanks a lot
  2. Hi Friends,
    Just found out a procedure. Is this the only way or there are some other easy ways too?
    Mar 2008
    Originally Posted by Russell18 View Post
    Hi Friends,
    I don't understand your question. According to the article you set it and leave it and it works in the background at the system level -
    as long as you have a sound chip / driver that supports it.
  4. Since Vista all audio processing (DSP) is performed by main CPU thus audio processing may be part of the or driver or Windows audio subsystem (so called Audio Processing Object) and as such driver independent.
    Example of Audio Processing Object is https://sourceforge.net/p/equalizerapo/wiki/Documentation/
    Jun 2020
    new york
    Sound card can be more helpful to make that kind of changes.
