Hi all. Been kicking around an effect that I thought was going to be easy, but not finding it. The idea is simple: Have it look like the screen has not refreshed. i.e: everything in each previous frame remains, and next frame is just superimposed. I've seen it done in capturing birds in flight, etc, to show patterns of movement. But not looking for a "blur" effect or the like, but a way to track changes in information gathered. Just like when your gpu is crashing, and you see the trail of the cursor across the screen. If anyone can recommend particular editor or effect available to cracked version of photoshop or illustrator, that would be great.
thanks!
Closed Thread
Not totally sure I correctly get what you want, but to me it sound like you want to blend/merge x-frames together to get that usually is referred as ghosting,...
Googling for "frame trail ghosting" might give you some instructions how this can be done with different tools,...users currently on my ignore list: deadrats, Stears555, marcorocchini
is there a tutorial or some imputs to help me to create "slipt screen"
By rama in forum EditingReplies: 7Last Post: 13th Mar 2016, 09:18 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21 -
VHS to DVD - Turning off on-screen "STEREO" warning on Sony SLV X811 VCR
By 2prfm.com in forum Capturing and VCRReplies: 6Last Post: 18th May 2015, 13:44 -
[Help] Problems with the "Title Button" in the "VTS ROOT" and "VTS Normal"
By kirous in forum Authoring (DVD)Replies: 8Last Post: 1st Nov 2014, 12:31 -
How To "Stretch" 480p Video To Better Fit The Screen
By LouieChuckyMerry in forum DVD RippingReplies: 25Last Post: 31st Jul 2014, 01:07
