I have a Samsung 5 series tv, that is about 7 years old. I do play series on the tv, that I have downloaded, sometimes the audio is not working, but I know how to fix it with Avidemux, but now a few of the series thst I download have a video problm tht cannot play on my tv, how and what video format must I use.
Did try to convert from mkv to mp4. but it is not working.
Are you sure it isn't a profile or reference frame problem on your tv rather than hevc? I had a Philips TV once which struggled to play h264 files with more than 2 ref frames causing picture pixellation and audio out of synch. Maybe you can flash/ update your TV with newer firmware. Recoding files just causes video quality loss. If it is a profile/level issue try changing the level first. Might work. If it is just a mkv container issue then change the container to mp4 with Rebox.
https://www.videohelp.com/software/H264-AVC-Level-Editor
https://www.videohelp.com/software/rebox.NET -
In a different thread a user complained about his Samsung UE40EH5000W (2012) suddenly having troubles with certain files. We found out files created by x264 r2945 and older are fine, files created by r2969 or later don't work (unless interlaced + b-frames). This seems to be a Samsung bug. If you use MediaInfo as suggested by jagabo you will often see what x264 version was used.
M3u8 channels not working in Samsoung smart tv but working in vlc player
By alaasl3 in forum Video Streaming DownloadingReplies: 18Last Post: 15th Apr 2019, 03:47 -
How can use this code to encode video?
By yasinaslan16 in forum Video ConversionReplies: 1Last Post: 16th Jan 2016, 09:09 -
looking for the video link inside the video_source code
By vhelp in forum Video Streaming DownloadingReplies: 12Last Post: 13th Sep 2015, 11:04 -
how can code me a custom video edit software ? please need help.
By MS-HD in forum ProgrammingReplies: 0Last Post: 2nd Aug 2015, 07:06 -
Video embed code
By hcs in forum Newbie / General discussionsReplies: 5Last Post: 30th Jun 2014, 09:36
