i am using 64 bit blender 2.79 on ubuntu 18.10 64 bit. i can export to any codec except dnxhd. when i try it it gives a log ouput that reads:
[Attachment 49369 - Click to enlarge]
whats the problem here?
Looks like you have the wrong framerate ("0/0"?), and possibly the wrong resolution (if you used anything but the 80/100Mbps setting). DNxHD only supports the NTSC & PAL standards, so 29.97i (aka 29.97 fps, 59.94 fields/sec) for NTSC, or 25i (aka 25fps/50fields) for PAL.
Scott -
after setting blender to 1440 x 1080 fields bff and the bitrate to 110 000 fps 29.97 still no joy .
While internally the stored resolution for that setting is in truth 1440x1080, I’d bet that the codec expects its input to be standard 16:9, therefore 1920x1080.
Or is your clip supposed to be 4:3?
VSDC export
By Čamo in forum Newbie / General discussionsReplies: 0Last Post: 24th Feb 2019, 06:59 -
Blender - Subtitling with 'blend-sub' add-on
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 29th Sep 2018, 20:13 -
FFMBC - problems converting to DNxHD 185 10-bit codec
By Benoit in forum Video ConversionReplies: 1Last Post: 18th Aug 2016, 01:43 -
Do DNxHD codec is free for commercial use? Do you charge for MPEG.LA
By createstock in forum Newbie / General discussionsReplies: 0Last Post: 3rd Apr 2015, 05:57 -
Prores vs DNxHD
By SameSelf in forum Video ConversionReplies: 12Last Post: 28th Oct 2014, 17:23
