I'm hoping someone can help. I have a video file that after the first 7 seconds; stops playing. The file size looks good, I want to fix that second or two as so the video plays though to the end; hoping it's only a second or two which is causing the video to stop playing.
What type of file is it? If you use the seek bar to zip past the bad section does it play the later parts of the video? Have you tried different players? Try a simple remux with mkvtoolnix.
It's an MP4 file. I tried using the seek bar to zip past it with the player I use; didn't work. I'll try another player in the mean time, although I'm doubtful it will work, although I'll try. How do I use mkvtoolnix, from the basics on me using this tool, it didn't solve the problem, it created an mkv file but same issue.
First 2 seconds lag when playing on PotPlayer x64
By savvyguy in forum Newbie / General discussionsReplies: 0Last Post: 25th Dec 2018, 20:47 -
Problem with .TS sTREAMS (STOPS AFTER FEW SECONDS)
By crazy_canuck in forum Video Streaming DownloadingReplies: 4Last Post: 7th Jan 2018, 20:34 -
VLC waits 3 seconds before playing video bec. of subtitles (file attached)
By smellycat3 in forum SubtitleReplies: 8Last Post: 30th Dec 2015, 06:29 -
Sony Bravia 46KDL-W905A abruptly stops playing videos.
By ZikO in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Nov 2015, 05:27 -
JVC BR-DV3000 stops playing after a couple seconds.
By gwjones12 in forum Capturing and VCRReplies: 2Last Post: 15th Jun 2014, 12:22
